Fuel Pump Poll
281 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Jason,trust Nengun as I have bought some things off them that were quite expensive and always turned up.Including the Nismo pump and am wrapped in it.Quiet,strong flow,and has all wires attached with it`s own frame.Simply pull the old one out and throw it away as the Nismo is complete.
Yea thats the main reason im wanting to get a nismo fuel pump, i had a gtr fuel pump in my old r32 gtst and everyone said it would be a straight bolt in, but it turned out that i needed to modify the bracket and filter bag, was a pain in the arse, so ive decided to spend a little bit extra this time and go for something that will bolt in with no hassles, i think i will place an order with nengun soon (might also get a blitz lm fmic kit and a few other bits and peices) everyone seems to trust them and ive never heard of anyone having a problem with them so thats good.
Cheers mate
  • Replies 65
1) Bosch 040 - internal
2) 33 GTST, mild mods, std turbo, approx 200kw
3)
- Ease of installation: pain in the ass to get the fuel new pump back into tank.
- Noise level in cabin: no extra noise
- Starting issues: need to prime sometimes but no dramas.
- 1/4 tank syndrome: none. Because I modified the bracket so that the intake sits in the same place as where the stock sock did.
cheers
1- r33gtr pump
2- 33gtst exhasut,air intake,boost controller under 200kw
installation was not too good as i couldnt use the r33 rubber mount on the gtr pump so i took it to a workshop and they did it (dont know if they used anything to be honest)
noise level is ridiculous... loud when priming, softer when idling but still audible
no starting issues
1/4 tank syndrome not sure as i just installed it
cheapest and ok for up to under 300kw would be either a walbro one or a 33gtr one both can be had for about $150 if u know where to look
bosch 040 is good too but i think isnt rated as high as the above 2
someone correct me if im wrong and they are around the 200 mark
1. Walbro lift pump tp swirl pot. 2 x bosch 910 280LPH @ 5bar direct voltage feed. New 3/8 fuel lines and fuel pressure gauge in dash standard FPR
2. R32 GTR track car stock turbos, injectors ( not for long ) PFC pods etc. Installation was not to bad as swirl pot in the boot
3. Sounds like a group of migets belting seven shades of shite out of the back of the car. Very glad for very loud exhaust and helmet.
4. no issue with 1/4 tank stuff with swirl pot.
yer id also like a definate answer about the 040, Im looking to run close to 300rwkw with some love juice (c16) and daily 260-280 on PULP, the 040 is rated at a 500hp pump, I just dont want it on edge when running near 300rwkw
Then theres the option of 044 (internally) Dont really want a swirl pot and ext pump....
This is on a 20 BTW
-Jez
  • 3 years later...
  • 11 months later...
Thread dig.
I've recently purchased a bosch 044 already setup in the factory cradle from a 32 gtr to go in my 32 gtr. just want to know if anyone has had any problems with having these mounted in-tank at all?
Need a piece of advice...when installing aftermarket pumps do you need a Fuel pressure regulator? When does one need an FPR????
Cheers
Pretty much never unless you are too stooge to get big enough injectors and compensate by increasing rail pressure, that or you are running some stupid hp and decide a rising rate makes things easier to tune.
  • 2 months later...
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
