  • Replies 161
Guest Nightsky
but half you guys dont even own GTR . how do you know they are better than gtir? LOL .
true.
All I can say is I find it hard to compare such different classes of car. I mean they are both 4wd but were designed for totally different applications. That said if you pumped infinite dollars into both of them my guess would be they would be hard to fault in a straight line or round corners.... I am probably way off the mark but there's my spin on things.
Bottom line is that a GTi R is a great car...
And why compare a rally bred hatch to a Group A/circuit bred coupe? Doesnt make sense!!
Thats like comparing a LeMans 24 hr car to a Drag car....
Designed and built for totally different purposes so both have pluses and minuses...
Again: GTiR=Good car. :(
if the gti-r was such a great car nissan would have kept making them!
i looked at a few when lookin to get my skyline but the interior is nuttin crash hot! very exective like.
From a traffic light drag the gti-r might get the jump on the skyline but on a rolling start the skyline can pull away. Heck with only 155kw@wheels i ran a gtir 4 times with rolling starts upto 180 click and i had 5-6 car lenghts on him each time by 180.
I think you'll find that the GTI-R was only built as a homologation for WRC purposes. It didn't cut it at the top level as a rally car so they didn't need to keep making them. Doesn't mean they aren't a great performance car though.
GTI-Rs are great cars,
SR20 is proven
Quad throttle body
Light and AWD
Respond well to mods - you can get hell gear for them
But - you MUST get an oil cooler for them or the engine will fry.... (if pushing then hard)
Also handy for a dinner party when you are serving grated Parmesan and Spag Bol.......
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
