Hi all,
I'm wrecking a R33 GTS T sedan, series I Oct 1994 gunmetal grey in colour. The damage is around the B pillar and roof on the passenger side, so the front passenger door is no good, and there is a slight buckle in the roof just above the B pillar on the passenger side. I have already bought another GTST which is an auto, so all the parts I need to do the manual conversion is not for sale eg, gearbox, diff centre, tailshaft, centre console, clutch and pedals.
Otherwise everything else is for sale. For all small items please PM me for availability and prices.
I'm on the central coast in NSW and travel to Sydney regularly, so I can bring parts to Sydney for inspection if required.
RB25DET engine complete with loom and ECU (Between 80 and 90k)( I have a manual and auto ECU) you choose which ECU. $1950.00 (AFM, radaitor, aircon compressor, power steering pump and alternator separate).
RB25DET engine 225K, broken ringland in cylinder 1. All other cylinders have good compression. Will separate all parts. Motor was still running when removed. Was only removed due to lack of compression in cylinder 1
Full rear cradle with diff from GTST auto $750 (not available until Feb 2007)
ABS system to suit R33 complete with all harnesses and all brake lines $300.00
I have a whole car to wreck so please PM me with anything U need and I'll give U a price and send some pics
As I get through different stages of wrecking the car, I'll take photos amd post them to see if anyone is interested in anythng
Update 27/1/07
Dash/console/glovebox removed. All items for sale. Please let me know if you're interested and I'll send pics of individual items.
Photo's of behind the Dash Area. Anyone interested in anything in these photo's ?? All wiring looms are fully intact.
View from Drivers Door
View from Passengers door
Edited by blukie
https://www.sau.com.au/forums/topic/150361-gts-t-r33-sedan-wrecking/
Hay champ.. Could you please send me some pics of the aircon hose.. The one from the firewall to the compressor..
As long as that hose doesnt have a hole or anything in it.. i could be keen.. Should be the one with heatwrap around it??
But please do send me some pics
Cheers
Edited by siddr20
siddr20 - I just had to find a new one of those pipes (side suction pipe i believe its called), they have different size nuts on the part that connects to the firewall thread from model to model. Make sure you got the right size one, as I bought one off a 97 model s2 r33 and it didnt fit my 96 series 2 r33!! shithouse.
Cheers
Howdy, I'm sorry this hose is cut.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
