  • Replies 40
Before yor freak out too much - put it into context.
How mch does the average (say used $20k) Falcadore devalue per year? Maybe $2k? The imported SKyline is unlikely to be much worse.
Also - if you are anything like me, the cost of mods over your few years of ownership will probably far outweigh the cost of devaluation.
Bottom line, if owning and driving a Skyline makes you happy - keep it.
If you are going hungry and/or are about to be divorced, kicked out of the folks house, locked up for not paying speeding fines etc - then sell it.
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-309719
Well that's what I thought would happen! But it seems not so far! Someone said that the GTRs in Japan were going to be giong up in price because they knew about the Aussie 15 year thing :confused:
Ahhhh well stuff it I like my car I'm gonna keep it :P
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310143
I wouldnt worry dude. As I said in another thread the whole 15 year thing is going to be changed to 20 years to prevent all the good stuff coming in. The quality of the '89 stuff will be pretty low, I mean how good is a GT-R going to be after 15 years of caning?
Jash
PS I waved to you yesterday
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310749
R31 GTS imports are not a lot cheaper than R33 GTSs ($15000 v $20000) so don't panic. HSV cars drop in value the price of a R33 GTSin about 3 years so spot the Dick heads.
A mate wanted a Jash GTR a while ago and needed to sell his
HSV to buy it the car is better than new condition and Colin
could not get 1/2 new price so a 20grand R33 GTS could be
burnt in 3 years and still not loose as much as a Heavy Slow Vehical
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310761
yeah but steve the GTS R31s are relatively rare and are collectibles, whereas the 32 GTRs are still fairly prolific.
one of the biggest differences in the prices is related to the difference in the processes required for import.
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310790
Jash
So do you think they will change it to 20 years?
The people who buy cars now will be pretty pissed!
PS I waved back but couldn't get my hand up through the gap in the window quick enough and you had turned your head back :P
PPS I like that Stagea! :P :burnout:
https://www.sau.com.au/forums/topic/15080-value-of-our-cars/#findComment-310995
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
