Hey everyone. This is my first post as I've just joined up today. Been browsing for a while though.
I'm going up with my friend Guy Baxter. We'll both be driving my car '90 300zx NA. I've never done on of these before so I'm sure It will be good for you guys to watch a newb struggling. lol.
I think we're planning on going up on friday night too but after midnight as we both have work.
Sandeep
  • Replies 204
Posted Images
Welcome aboard - you'll have a blast!
As far as tips go...
1. 300s go better with the t-tops off and better still if the driver has a Bandit hat or mo
2. Use your stereo to psych-out opponents on the battle runs
3. Don't hit cones
4. Bax will never beat the Lancer!
J
hey guys I have renewed my Cams licence as of about 3 weeks ago but they haven't sent me a new card or debited my credit card... I am getting a little nervous as I don't want to rock up to DECA empty handed... does anyone have a contact at Cams I can speak to?
This is their phone number is Malvern - (03) 9593 7777
Call and speak to someone in licensing.
Also Nick, Im not sure if they allow it, you'd have to ask, but if it helps you any I can pick up your license for you and bring to DECA (I drive past twice a day :laugh:).
your always quick to respond and organised Bec... I need you at work!
I will call and check out the status of my licence and let you know... cheers:)
Nick - 9593 7777
Call and ask for membership services. Usually they can at the worst fax you something that you can use to say you have renewed.
Cheers
Snowy
That James fella is a cb hoarder. He's got 2 of mine as well.
I second that as I had to ask for mine back! Probably a secret stash at the mansion which is why he has so many to offer at subsequent cruises! :P:laugh:
Something to note for DECA's from now on.
As part of AASA's Public Liability Requirements SAU now has to provide a full list of all licence numbers from all entrants on the day.
This should always be the case anyway, but if you fail to produce your licence on the day for us to record the number, then you will not be permitted to drive. If you are signing up for a licence on the day this is fine also, but please be prepared and bring a completed AASA or CAMS club racing licence application form and correct money.
Thanks.
Also if you have written TBA on your entry form and you now know your licence number or can get you licence number, wheather it be CAMS or AASA, can you please PM me this number before Thursday night? This will make things run a little smoother at registration, and get you all out on the skidpan quicker.
Ta, Chris.
is there any official friday night, saturday morning cruise? i know james said he would do the friday night and ferni was going saturday morning from lilydale. Anymore details on that? where and when?
:laugh:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
