Crazy Gen-TT Skyline Fires Up!
[flamesuit on :(]
For those that have been following the progress of the LS1 and Gen-TT R34 Skyline being built by GT Autosound in Adelaide, the good news is its now fired into life, and man its one mean sounding Skyline!
Listen to the engine as GT George gives it a good solid rev for the Camera!
(Right Click and Save Target As)
http://doughy.theddrzone.com/MOV00705.MPG
https://www.sau.com.au/forums/topic/152366-crazy-gen-tt-skyline-fires-up/
The LS1 would be lighter would it not?
All alloy. :)
With all the rest of the bs there i doubt the f/r weight balance has improved at all. Its still more than twice the capacity of a 2.5, double the turbos etc. more pisons more rods etc etc. Just because the block is alloy doesnt make it all good.
A rotor would have been a better choice
However if it did end up with a weight balance same as stock or better i would be a huge fan :happy:
btw gotta love the chopped rad support :)
Also im sure cars like this are great at getting people from both worlds together and into their workshops spending money. But how great will the car be in a drift comp, i dont rem the pink s15 every achieving much...
GT autosound are a car audio shop... do they even do this sort of work for the public?
However if it did end up with a weight balance same as stock or better i would be a huge fan :)
an ls1 weighs about 400lbs, where as the RB weighs around 700lbs
it is only as long as an I4, so it sits further back in the engine bay
so not only is the whole car lighter, there is better weight distribution.
no matter what way you try to skew it, it will come out lighter
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
    • It's either an ignition failure or a fuel failure.
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
