Crazy Gen-TT Skyline Fires Up!
[flamesuit on :(]
For those that have been following the progress of the LS1 and Gen-TT R34 Skyline being built by GT Autosound in Adelaide, the good news is its now fired into life, and man its one mean sounding Skyline!
Listen to the engine as GT George gives it a good solid rev for the Camera!
(Right Click and Save Target As)
http://doughy.theddrzone.com/MOV00705.MPG
https://www.sau.com.au/forums/topic/152366-crazy-gen-tt-skyline-fires-up/
The LS1 would be lighter would it not?
All alloy. :)
With all the rest of the bs there i doubt the f/r weight balance has improved at all. Its still more than twice the capacity of a 2.5, double the turbos etc. more pisons more rods etc etc. Just because the block is alloy doesnt make it all good.
A rotor would have been a better choice
However if it did end up with a weight balance same as stock or better i would be a huge fan :happy:
btw gotta love the chopped rad support :)
Also im sure cars like this are great at getting people from both worlds together and into their workshops spending money. But how great will the car be in a drift comp, i dont rem the pink s15 every achieving much...
GT autosound are a car audio shop... do they even do this sort of work for the public?
However if it did end up with a weight balance same as stock or better i would be a huge fan :)
an ls1 weighs about 400lbs, where as the RB weighs around 700lbs
it is only as long as an I4, so it sits further back in the engine bay
so not only is the whole car lighter, there is better weight distribution.
no matter what way you try to skew it, it will come out lighter
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
