Hey ppls,
The R32's (unsure about R33 or R34's) have an engine overheat fan positioned on the aircons condensor.
The engine over heat fan ONLY turns on when the water temperature reaches ~92-94degree's. The temp sender switch is located in the bottom tank driver side of the radiator.
This overheat fan does NOT turn on when you hit the A/C button.
Having the engine overheat fan turn on with the A/C allows air to pass over your aircon condensor when stationary, this improves the aircons efficiency/coolness and reduces engine temps (at the very least slows the increase in temp when sitting in traffic). This is especially critical if you have had your aircon converted to the R134a gas.
The R134a gas is not as efficient as the old R12; it runs a much higher head pressure, places a greater load on your compressor and places a greater heat load on your condensor.
Forcing your overheat fan on with R134A when the a/c is in operation WILL improve your aircon's coolness during long periods of idle or very slow speeds.
Most Aussy released cars automatically have the 'engine overheat' fan enable when you hit the a/c button.
Its required for our hot climate during heavy traffic.
Having my aircon recently serviced I decided to do something about having the engine overheat fan turn on when I hit the A/C button.
I remembered the A/C and Engine Fan relays were situated next to each other in the fuse/relay box under the bonnet.
See below pic.
I grabbed the multimeter and found the trigger on both relays which happens to be the far left wire on both relays. Do note the wiring is negative switching; the relay see's a constant battery voltage, only when the relay is earthed does it activate.
Please do check yours to ensure you have the right trigger wires.
Mine were:
A/C - Green wire Yellow stripe
Overheat Fan - Green wire Black stripe
See below pic.
I bridged the wires and presto... The engine fan turns on with the a/c. BUT the problem here is the a/c now also turns on with the engine over heat fan when the engine overheats (~92-94degree's). See below pic.
The solution to having the a/c turn on when the engine overheats is to use a SINGLE DIODE!
As the relays activate when earthed place the diode appropriately. See below pic.
So its as simple as that. Head down to Jaycar, grab a meaty diode (~0.25c) and splice it in to the trigger wires.
Be bugged wiring in another relay; this is a cheap very tidy solution.
Good one! So the diode (one-way only) stops the A/C from seeing the fans ground? But the fan can see the A/C's ground, so it comes on.
I was keen to do something like this!
Oh, and to confirm, my 33 doesn't switch the fan on when the A/C is on either.
All done. :D
I ended up using a little wire to position the diode away from the loom so to speak.
There's just not enough room in there.
A flux pen gives very very tidy solders as it literally sucks the solder off the iron and evenly spreads it.
I have solder with a flux core but there's just nothing like having flux on the item that you are going to solder.
I first covered the joins etc with liquid elec tape. Why? Because I had some laying around, liquid elec tape tends to go soft with heat. So its not that crash hot but does keep water out.
And now all taped up.
You can only just see a little bit of the white wire under the relays. :no:
Stoked I didn't have to bugger arse running another relay and chopping in to wires that really wasn't required.
Remember your all smart individuals, its up to yourself to perform your own research and decide IF you should attempt this mod. I'm not going to be responsible for you breaking something. :yes:
I have been thinking the same thing Cubes, and the same issues (S2 97' GTST) Has anyone worked out yet what relay/pins the R33 fan runs off? I was just going to splice in my own relay/find a spare and have a switch to manually turn the fan on.
Chris,
If you have both the A/C and Rad/Blower Fan relay on your fuse/relay box then you will be able to perform this mod. :yes:
Have a read up on automotive relays, from what I've read automotive relays are usually negative switching.
It really is easy, have a play with a multimeter for a while, you can't short or blow anything up testing with a multimeter so fear not. :D
Thanks mate! You have helped to answer a question that I have had for a number of months :yes: Now I have no excuse to get stuck under the bonnet with a testing light and get it sussed out for once and for all.
I'm planning on hooking my thermo fan up to this, so I tested the on/off temps last night (via CONSULT), so for the record on my R32:
*** The fan switches on at 91C with a 3C hysteresis (i.e. off again at 88C). ***
When you say it "stays on", you mean after you turn the AC off, yes?
The std Ran fan is attached to the engine, so it's obviously, always on.
As for the AC one, remember it's an overheat fan, so your car could be running at 91+C and triggering the fan that way.
But don't be scared by the word "overheat", 91C is fine (your temp needle in the instrument cluster doesn't hit "Hot" until closer to 110C), it's just used to help out the clutch fan in hot weather etc.
Easy way to find out.
Hit the a/c button and the fan should 'instantly turn on.
If its cycling in and out when the a/c isn't then check engine temps and you may very well find that is whats activating the engine overheat fan.
Yes.. Run a wire from the rad fan relay in to the cabin, in to a switch and then earthed. (remember the relays are negatively triggered)
But why would you want to do that?
Just have it activate when you hit the a/c switch like aussy cars do.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
