Dropped by my local Jaycar store and had a look in their catalouge and found a kit which will solve all our problems :pwned:
Car Air Conditioner Controller Kit
This kit stops the air conditioner in your car from taking engine power under acceleration. It will allow the compressor to run with low throttle even when the cabin temperature setting has been reached and will automatically switch the compressor off at idle. it also features an override switch and an LED function indicator. Kit supplied with PCB with overla and all electronic components.
Recommended box UB3 HB-6013
$39.95
Cat. KC-5437
Someone buy it and install it :O
- Patrick
https://www.sau.com.au/forums/topic/153594-no-more-lag-with-air-conditioner-on/
Not an entirely bad idea...
I think i'd rather have mine turn off when i'm on throttle but below 1500rpm. Every time it's on and I take off from the lights there is so much horrible lag that you really need to ride the clutch a bit to be smooth. On at idle though... it'd suck sitting in traffic sweating to death!
As far as i knew the standard computer turns it off on WOT anyway, atleast the Z32s do, guessing the RB powered cars would be the same.
If you need to turn it off, run more boost because your car musn't have any balls to begin with.
Solution: I perscribe a case of harden the fark up and get rid of your AC totally, followed by using your power window button and harness the wonderful noew power of wind to cool you down :(
werd!
i sometimes use my A/C and it doesnt give me any lag.. ?
ive never had a problem with my A/C and lag. As for you non-air con guys, ill gladly take a few camp jokes and continue to sit in comfort on those 30+ days without sweating into my expensively retrimmed leather pews, whilst i have a chuckle at all the guys with the windows down trying to look like they arent hot, obvious to me that if they had a functional air-con, they would use it! :O
Part of the reason why i own a skyline is that it does everything, comfort on hot days included. Getting rid of the aircon on purpose, to me is like ditching the power steering! why would you?
Edited by SLY33
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
