Hey guys.
I searched hard and found a lot of people who were interested in the Greddy Pulley Kit (standard direct swap sizes) as well as a lighter, carbon tailshaft but no reviews at all. A hell of a lot of speculation and physics lessons were found, but no one actually left any real reviews.
I've linked up the parts in question below. Would appreciate your comments, experiences, opinions. I'm sure some of you out there would be keen on these items as well.
GREDDY WATER PUMP, ALT AND POWER STEERING PULLEYS MADE FROM DURALUMIN (A2017) ANNODISED BLUE FOR R32, 33,34 GTR. LESS THAN HALF THE WEIGHT OF FACTORY STEEL ONES FOR IMPROVED THROTTLE RESPONSE.
UAS ONE PIECE TAIL SHAFT FOR NISSAN SKYLINE GTR. LESS DRIVE TRAIN POWER LOSS, MORE RESPONSIVE - LESS LAG.
WEIGHS ONLY 9KG COMPARED TO FACTORY ITEM AT 14.5 KG
SUITABLE FOR R32 AND R33 GTR
https://www.sau.com.au/forums/topic/153711-lighter-pulley-kit-tailshaft/
  • Replies 65
I was talking to a guy that makes tailshafts in Adealide. He was telling me the longer you make a shaft the less rpm you can spin it at, when you are at around 1.3 meters you will be lucky to get 5000 rpm out of it so thats why you go multiple peice. So it may not be that smart on going to a single peice shaft depending on RPM and length.
i run a one piece carbon tailshaft, and it is almost half the weight and we spin it to 8200 rpm also its rated to 1500 hp.
cheers russ
p.s we also dont have problems anymore with driveline shudder from the centerbearing on hard launches with the carbon one piece shaft.
Edited by giant
cheers russ
Hey Russ, where did you get this tail shaft from?? Local or overseas??
GTR shafts are shorter than GTS-Ts due to transfercase on back of gearbox so they aren't that long.
Got a mail back from ACPT and my carbon shaft is on order!
ACPT driveshaft is $1400.00 for the version 1 (800 ft/lbs of torque) plenty for my circuit car, they also make a bigger one, slightly heavier and more expensive, for drag cars with up to 2000ft/lbs of torque. $200-250.00 for overseas shipping.
I'll let everyone know how it goes!
Any weight loss of a rotating part will be beneficial.
Still, from what I understand, weight is only one factor in the equation, the other is the diameter/distance that weight is located from the source.
So a lighter tailshaft may be offset by an increase in diameter of the shaft, i.e., standard 2.5" diameter standard shaft versus a newer lighter but 3" diameter shaft. I guess for tailshafts it would only be a slight increase in diameter and probably wouldn't have much effect going to a larger one..... but in terms of flywheels this is the case.
Fixxxer :)
hey mate as linked below
http://www.acpt.com/driveshaft/driveshafts.html
just dont hold you breath on there response times toook them awhile to get mine out to me , but as very happy with the product and has never failed even with heaps of abuse, no launch shudder ever!!!
and 6 odd kilos lighter
cheers russ
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
