Very simple...
Lag is the time it takes a turbo to come onto full boost; so as an example you may get full boost @ 5000rpm so your lag time is the time it takes ur car to go from 0rpm to 5000rpm
ways to fix lag;
-smaller turbo
-cams
-better flowing head
-ebc
-antilag
https://www.sau.com.au/forums/topic/153765-turbo-lag/#findComment-2859500
ill take 2 thanks Az.
make them the big ones, and az, i need them by tonight
hahaha i feel like im in the movie.
Sadly there is no overnight parts service that does not cost less then ones left nut. :devil:
To put it simply.
Lag is the process of building up air pressure/flow mass to increase shaft speed within the turbocharger to generate positive pressure.
Until the desired boost pressure is met this is referred to as lag.
To decrease lag, smaller and lighter internals can be used within the turbocharger to increase shafts speed. (smaller turbocharger)
Lag means horsepower though :P
https://www.sau.com.au/forums/topic/153765-turbo-lag/#findComment-2859604
turbo lag comes from the compressor not being efficient until it reaches a high speed, say 50,000+ rpm? when the compressor isnt spinning fast enough it doesn't produce much positive pressure or airflow so the engine just is burning whatever air comes in. as the compressor gets faster and faster from exhaust gas/engine load the compressor beings to "compress" the intake and stuff more air in.
when there is little exhaust gas the compressor doesnt spin fast enough, so its referred to as lag. common for the skyline range is nothing before say 2500rpm. past this theres enough exhaust gas to wind the compressor into its effiency zone and usually get around 10psi positive "boost" pressure before 3000rpm.
as engine displacment and type changes, along with turbocharger technologoy, engine tune etc so to does the engine lag. so there are a few things you can do to reduce turbocharger lag
https://www.sau.com.au/forums/topic/153765-turbo-lag/#findComment-2860523
Turbo lag is when you order your turbo and they haven't got any and it will be a two week wait.............thats real lag.
hehe the WORST lag ever. I think we have all been thru that type of lag from time to time. :down:
I am suffering form differential mechanic lag at the moment. it is taking 2 weeks and counting to spool up... :(
https://www.sau.com.au/forums/topic/153765-turbo-lag/#findComment-2860801
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
