would standard pistons and rods be good for 300rwkw?? i am looking to run a rb30 with stardard bottom end
rb25de head gasket
r32 rb25de head with rb26 valve springs, gtr cams and standard manifold.
what sort of turbo would be best for 260-300rwkw, i am thinking a holset hx35 or a garrett 3040.
does that sound like a good idea. i would like any feed back people have
thanks
it's been mentioned in this thread that the GTRvalve springs can't easily be adapted for the rb25de head.
it would be easier to use the 25det valve springs.
it also been said that with GOOD tuning and supporting mods, keeping boost low, with correct sized turbo, 300rwkw can be achieved using stock na pistons and rods and stock gaskets.
but constant high revs will destroy the stock rods.
not sure about GTR cams in teh 25de head either.
standard manifold is ok.
turbo selection..... I don't know.. not up to scratch with my turbo knowledge in terms of what power the turbo's you've said will produce and at what boost levels.
I think you'd need to be a bit more specific with things like exhaust wheel size and so forth.
Is there a workshop in melbourne that has done the rb31det conversion before that you guys would recommend?
Was going to do most of the work my self but after reading about all the crap people go through with pistons and what not i think i would rather have a warranty.
Id asked this question before.
How does the ECU tell what gear the manual gearbox is in?
The Haltech has boost correction dependant on the gear selected, so i plan to use this to soften the power delivery in 1st gear once boost is wound up.
it seems the "search this thread" option is no longer available.
however, SYDNEYKID had stated that GTR valve springs are not a direct replacement for RB25de heads.
it was due to the lifter in 25 heads not being the same setup as the 26 head.
he mentioned that in his first RB30 build when he used the 25de head from an R32, he changed the valve springs and used 25det valve springs.
maybe he'll see this post and confirm or correct me.
I have a sensor on 1 front wheel which picks up 5 pulses/revolution. You then calculate how many pulses will occur in 1km and enter this value into the sofware. You work out what each gear ratio equates to in kmh/1000rpm and enter the results plus the required boost correction for each gear and plug this into the software.
The ecu now has a speed reference via the wheel sensor in km, and by using the kmh/1000rpm figures plus the engine rpm it can determine which gear you're in.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
