they will handle 300awkw, but it (like GTR boxes) depends on the prior condition and how it is treated once you have this power. They are n't quite as strong as the gtr box as the the input shaft isnt quite as beefy.
What do you want to know about them?
Ok, on their website;
Here
theyhave different sizes, materials (steel or aluminium), outer diametre ect ect...
To chase a high horsepower application (1,000) which one would best be suited.
Would a larger outer diametre with 3 ring setup help reduce harmonics as there is more weight to counteract?
I can get them for about $950.
My Gts4 came with, hks turbo, power fc, aftermarket fuel pump, 3" kakimoto exhaust, hks plugs, hks filter and 4 balled tyres so i guess it was setup for thrash ;), perhaps thats why it has a gtr box! Clutch was Gtr when i took it out too , do the gts4's have an lsd, when i do a sharp turn at about 5kph up a hill sounds like i have a locked diff, sounds like one of the rear wheels is moving faster then the other???
Edited by FOOLBOOST
yes that sounds about right, hope it wont have problems with the extra torque, out of the following considering lets say 320rwkw with the rb25/30 with 1050kg gtr clutch i have in there what is most likely to go first.
1. Gearbox
2. Cv's
3. Drive Shaft
4. Diff
Not the cv's, drive shafts or diff as they are the same as GTR's and very rarely do you have problems with them. Even at that power, you will have to be a nice guy to your gearbox, depedning on its condition and the life its led, always be gentle on 3rd once you have over 300rwkw!!!
No its no one from here, its not really bagging just stating he'd like to know who supplied him the adaptor plate, I'm assuming the problem is the same as what I've heard, holes didn't line up perfectly, and it must be perfect when dealing with countersunk bolts.
RIPS did the first 4wd rb30det that I know of over in NZ, he's been around for a long time playing with these things.
He was the one to tell me the std rb30 oil restrictors are borderline but ok.
' date='17 Jun 2006, 05:02 PM' post='2264503']
A quick question re injectors
I have nismo 740cc injectors in my s15 greedy plenum.
Would these also suit the GTR head? (R32 or 33)
pretty sure s15's are side feed, rb26's are top feed!
unless for some funny reason greedy changed there stuff to suit top feed as well as ive seen some aftermarket setups.
but yes generally SR, r33 RB25 = side feeds, RB20,26 = top feeds.
tho if you can get 6x side feed s15 inj's they flow more fuel than the stock r33 items.
Hello .................... over here ............... RB30DET in R32GTR, started in 1999 finished in 2000
Shall I show you the first post on SDU, where I told RIPs the principles?
He can probably lay claim to the first R32GTS4 with RB30, no argument there.
In 1995 we also did a very early (not the first, but close to it) RB30 "D" ET, using an RB20DET cylinder head.
I need to check the exact numbers but I think we are up to ~10 X RB30's with 4wd.
The quality of the supplied adaptor plates (the race team fabricator doesn't have time to make them any more) has been steadily improving with our input. So what was a minor irritation 12 months ago, no longer exists.
:) cheers :D
:D cheers :(
heheh opps. :)
I now know differently.
Guys;
Just wondering how RB30s are treating hard driven (not abused) GTR and RB25 gboxes. I did a search on 'gearbox' here and got some threads from 2003 but that was it; found references to 320 rwkw being well wthin the capacity of the RB25 box, and the GTR box running happily with 650 hp (fly I assume) but not much on torque capability.
I'd hate to have to detune an RB30 so that the gearbox will live and I don't want to shell $5k for a gearset.
Cheers
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
