they will handle 300awkw, but it (like GTR boxes) depends on the prior condition and how it is treated once you have this power. They are n't quite as strong as the gtr box as the the input shaft isnt quite as beefy.
What do you want to know about them?
Ok, on their website;
Here
theyhave different sizes, materials (steel or aluminium), outer diametre ect ect...
To chase a high horsepower application (1,000) which one would best be suited.
Would a larger outer diametre with 3 ring setup help reduce harmonics as there is more weight to counteract?
I can get them for about $950.
My Gts4 came with, hks turbo, power fc, aftermarket fuel pump, 3" kakimoto exhaust, hks plugs, hks filter and 4 balled tyres so i guess it was setup for thrash ;), perhaps thats why it has a gtr box! Clutch was Gtr when i took it out too , do the gts4's have an lsd, when i do a sharp turn at about 5kph up a hill sounds like i have a locked diff, sounds like one of the rear wheels is moving faster then the other???
Edited by FOOLBOOST
yes that sounds about right, hope it wont have problems with the extra torque, out of the following considering lets say 320rwkw with the rb25/30 with 1050kg gtr clutch i have in there what is most likely to go first.
1. Gearbox
2. Cv's
3. Drive Shaft
4. Diff
Not the cv's, drive shafts or diff as they are the same as GTR's and very rarely do you have problems with them. Even at that power, you will have to be a nice guy to your gearbox, depedning on its condition and the life its led, always be gentle on 3rd once you have over 300rwkw!!!
No its no one from here, its not really bagging just stating he'd like to know who supplied him the adaptor plate, I'm assuming the problem is the same as what I've heard, holes didn't line up perfectly, and it must be perfect when dealing with countersunk bolts.
RIPS did the first 4wd rb30det that I know of over in NZ, he's been around for a long time playing with these things.
He was the one to tell me the std rb30 oil restrictors are borderline but ok.
' date='17 Jun 2006, 05:02 PM' post='2264503']
A quick question re injectors
I have nismo 740cc injectors in my s15 greedy plenum.
Would these also suit the GTR head? (R32 or 33)
pretty sure s15's are side feed, rb26's are top feed!
unless for some funny reason greedy changed there stuff to suit top feed as well as ive seen some aftermarket setups.
but yes generally SR, r33 RB25 = side feeds, RB20,26 = top feeds.
tho if you can get 6x side feed s15 inj's they flow more fuel than the stock r33 items.
Hello .................... over here ............... RB30DET in R32GTR, started in 1999 finished in 2000
Shall I show you the first post on SDU, where I told RIPs the principles?
He can probably lay claim to the first R32GTS4 with RB30, no argument there.
In 1995 we also did a very early (not the first, but close to it) RB30 "D" ET, using an RB20DET cylinder head.
I need to check the exact numbers but I think we are up to ~10 X RB30's with 4wd.
The quality of the supplied adaptor plates (the race team fabricator doesn't have time to make them any more) has been steadily improving with our input. So what was a minor irritation 12 months ago, no longer exists.
:) cheers :D
:D cheers :(
heheh opps. :)
I now know differently.
Guys;
Just wondering how RB30s are treating hard driven (not abused) GTR and RB25 gboxes. I did a search on 'gearbox' here and got some threads from 2003 but that was it; found references to 320 rwkw being well wthin the capacity of the RB25 box, and the GTR box running happily with 650 hp (fly I assume) but not much on torque capability.
I'd hate to have to detune an RB30 so that the gearbox will live and I don't want to shell $5k for a gearset.
Cheers
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
