Interesting.. Whats with the 2 lumps in front of each cam shaft on the cam belt then? :P
It was an N/A that I had a look at, I wouldn't have thought the turbo head would be any different.
??? The cas still bolts to the front of the exhaust cam, but it has a different spline
Are there any differences in the 26 and 30 headgaskets?
I have a VVT 25 head thats had the front right water jacket and oil gallery welded up and the water gallery shaped to suit the 30 block.
There appears to be more thicknesses available for off the shelf MLS headgaskets for the 26.
is there any issues running the RB25 gasket with the rb25det head?
obviously the oil feed is different, and will be modified for VCT externally..
Nope. I'm running the Cometic RB25 head gasket on mine without issues (~40,000kms). The price difference between the rb25 and rb26 was considerable at the time. I got mine from memory for $150.
Nope. I'm running the Cometic RB25 head gasket on mine without issues. The price difference between the rb25 and rb26 was considerable at the time. I got mine from memory for $150.
i got mine cheap but not THAT cheap ...
the rb25 cometic im running on the rb25 in the car cost me $330 :D
got some ACL piston rings, so its almost wash and build time :O prob 3 weeks
Thanks for that Cubes.
I've been looking at the cometic and ACL race series MLS gaskets, Prices ive got ranged from 210-350 for an RB30 MLS headgasket.
Its not really an issue with a 33 25 VVT head that I've seen but there is a 1-2mm of sealing on a particular spot on the front right water jacket. That is when you use a 30 block.
Just to be on the safe side I tigged the water jacket and VVT gallery up in the head and shaped it to suit the water gallery in the 30 block. Theres a min. 5-6mm of sealing now.
It was a better option that trying to braze weld brass to the side of the block like in this pic.
http://www.users.bigpond.com/twinvl/blockmod2.jpg
I heard the Non turbo rb30 pistons have less rings or sumting like that.. and dont cope with boost very well...
wen i was gonna turbo my rb30e, i was being told that the compression had to be lowered a fair amount from 9.0:1 to around 7 or 8:1 to stop pinging and detonation...
Why is it ok for a hybrid motor to have higher compression ratios? wont it ping/knock its tits off??
Jimbo
Whoever told you that didn't know what they are talking about
Jimbo
Jimbo
putting the 25/26 head on actually lowers the compression!
1. Because its a hybrid motor. Better designed head that allows you to get away with a little more static comp. :)
2. Its all in the tuning. Simply throw a stock rb30et ecu on an rb30e that has a turbo bolted on to the side of it and try to push 14psi through it and it will almost certainly detonate. So tuning tuning tuning.
So the guys running the R32 RB25DE heads. What sort of power are you guys putting through the inelt manifolds...has anyone gone to an aftermarket one and noticed an improvement in response/power
Hey fancy seeing you in these neck of the woods. :whistling:
AM-Performance is about to drop an aftermarket plenum on his within the next week or two.
Sky30 pushed 312rwkw through his r32 rb25de head running the stock exh. manifold and stock inlet manifold/plenum.
Thats the highest I know of on the R32 RB20/25 style plenum.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
