Okay! so it has taken me 1 entire month and a lil longer to read through this ENTIRE THREAD!!
so !
i have 93 RB25DE VCT in my R31 skyline..
i have a RB30 block all stripped apart and ready to go for a acid bath...
i will be usuing the 25de pistons so i should get around 10-5-1 comp ?
i am usuin tomei pon cams type b with exaust side adj cam gear...
also buyin harder valve springs and valves
i will have my VCT connected and working..
i will be usuing the RB25DE oil pump with the tomei oil restrictor...
i have a N1 waterpump
ummm std injectors DE afm extractors custom 3" intake 2.5hiflow cat back exaust
will be eventually tuned on my wold 3d V3... just need a loom for it..
i will get back with all the prices i have been quoted on for the gasket kit n piston rings n main bearings n all the other build parts...
anything anyone else can reccommend while everything is out and i am doing this conversion ?
it is staying NON TURBO... RB30DE
cheers..
brent
Congrats on reading the full thread and not asking 100 dumb questions.
Youll need to dek the block to use the rb25 pistons, but thats no big deal.
I would look ino sppending a little more on the camshafts, and getting a pair made, Tighe Engineering in queensland are doing a pair for me $880 for whatever grind i want, just that the poncams wont give you the full benefit, as your NA You could easy go to 280-290 deg without dramas.
May be well worth trying something like the ebay greddy copy manifolds, with a Q45 throttle body, as you need to get as much air in as possible.
The rest of it looks great, and if you need to upgrade the injectors later on, det injectors willl be easy to source(i dont know if they are bigger though)
is this a typo? Tighe did mine for $290 for the pair!
Im after opinions on diff ratios, what do you guys use?
I have a 32 gtst with a soon to be:
25/30 with 9.2:1 comp
256 cams
33 GTR 5 speed converted to rwd
GT35R (0.82)
Aiming for around 330rwkw mainly for the street.
I'm looking for a ratio that is ideal for the street and is highway friendly.
With the current 20det the revs sit on 3k at 100ks, It'd be nice to drop that down to 2k or a bit less to save on fuel and engine wear.
Cheers Alf.
Edited by Alf
The 25t box has a slightly longer 5th ratio than the 20t box; unsure what the ratio is within the gtr box. But to give an idea.
(Ignore what your tacho says; they read high. Consult the pfc rpm display) :laugh:
4.363 ratio at 100km/h is 2757 (146km/h in third @ 7000rpm)
4.11 ratio at 100km/h is 2597rpm (155km/h in third @ 7000rpm)
3.9 ratio at 100km/h is 2464rpm (163km/h in third @ 7000rpm)
3.69 ratio at 100km/h is 2332rpm (173km/h in third gear @ 7000rpm)
I went from a 4.363 to a 4.08 a noticed a drop in off boot torque; out of corners etc the car felt lazier and spent more time trying to accelerate through any lag. Essentially it made the car feel more laggier. Accelerating off the line the car felt much nicer in first gear and appeared to accelerate better even though it would wheel spin but second and third + didn't feel as responsive.
So.. I dropped the 4.3 ratio back in and it is a much more enjoyable sporty drive. :)
I don't do much if any highway cruising so the drop in 100km/h cruise rpm didn't affect me.
Once making some decent power the longer ratio 'may' be worth while as it will help getting it hooked up. I noticed it felt as if it was easier to control wheel spin in first.
(Ignore what your tacho says; they read high. Consult the pfc rpm display) :)
So.. I dropped the 4.3 ratio back in and it is a much more enjoyable sporty drive. :D
Way back in this thread SK has stated that the ideal diff ratio is 3.7 for circuit racing. I'd assume this would be using a higher comp and different box than yours Cubes.
ps: I'll using a 33 GTR box (suited to 4.1 diff gears) with the 25/30.
3.9 is looking good.
Edited by Alf
I have a clearance problem in my car... Does anyone know where to get a single belt pulley from to suit RB30/26 ??
I had to "modify" when i was RB20, but would prefer an off the shelf item if available. I have no a/c or power steer to run.
harmonic balancer?
i nkow the front pulley is rmeovable on the ross ones, not sure if the other 1 is or not, also not sure on the ATI ones
You skyline drivers have a 3 belt pulley system off the harmonic balancer to run alternator/air conditioner/power steer belts. I only require the 1 for the alternator and need it to be only 1 as i have minimal room to play with.
I will google "ross" and "ati" and check it out.
Cheers
Steve
Found some gearbox/diff ratio spreadsheets that might come in handy, dunno how accurate they are tho.
R33 GTR
http://www.sol.co.uk/h/hugh/R33%20Speed%20...alculations.xls
R34GTR
http://www.sol.co.uk/h/hugh/R34%20Speed%20...alculations.xls
OS Giken
http://www.sol.co.uk/h/hugh/OS%20Giken%20U...al%20ratios.xls
Edited by Alf
My list of parts so far for RB30/26...
HKS inlet cam - 264/10.0mm lift
HKS exh cam - 272/10.0mm lift
HKS step 2 valve spring set
HKS cam gears
HKS 680cc injectors
HKS fuel rail kit 11.0mm
HKS adj fuel pressure reg
ARP 2000 head stud kit
Cometic metal RB30 head gasket
Garrett GT35R 0.7in /1.06 ex
Engine goes into the builders next week and i'm undecided on pistons as yet, but i think i want about the 8.2 compression ratio. I'm in the hands of the engine builders expertise now. *fingers crossed*
maybe whack in some arp main studs, at a bit under 200 its a bit of safety with a build like that
also what size head studs u go for? 26 ones and re-tap the block? or 25's and live with the slop...
202-4207 to suit RB26...
Yeah i will fit it out with the arp gear down below. Better safe than sorry :P
Edited by RB120WHY
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
