Where have you people who are using R33 heads been plumbing you oil return pipe from the front right hand side of the head? do you get a "T" peice and blumb it into the turbo drain into the sump?
cheers :P
After a lot of hard work and long nights my RB30det is now in the car.
I have spent a few hours tonight trying to get it started and have not got there yet. this is frustrating
Fuel pump working - check.
CAS working - when i remove it and rotate it with the ignition on the injectors click and the fuel pump turns on
everything is wired up bar 1 plug on the AAC valve. the r32 loom has no provision for it.
I am still working out the best way to test spark. any ideas?
I have had to use R33 turbo injectors and it involved cutting up the original loom and grafting in the plugs but I have done it before for GTR injectors and no problems.
the motor turns over fine just does not start
when the crank is set to o deg btdc the cams line up with the locator pin marks perfectly.
so its fuel or spark i am missing or some electrical gremlin somewhere. if anyone has any ideal please shoot them my way. my goal was to have it running by tomorrow night.
so so tired...
so so tired...
What ecu are you running? If aftermarket, what was it previously tuned for?
I am using the following bits
RB30E bottom end :P
RB25DE VCT head from an R33 - removed VCT solenoid and used the hole to feed oil to the head -
stock plenum R33
R33 injectors
R33 AAC valve
R33 tps, (all sensors on the head are R33
R32 CAS
R32 ECU remapped to suit the 370cc injectors
Will try the timing light tonight. hmmmm
wake up at 6am go to work finish work at 4pm. go home work on car till 1am. sleep for 5 hours - repeat for 3 weeks...
damn i am tired...
car should start with no afm, it'll just run like a pig and stall etc etc lol
it could be that ur battery isnt supplying enough juice
have u checked to make sure theres fuel getting to the rail?
thanks dudes :P
pulled the timing cover off and made sure the cas key is correctly set to the cam key.
the afm is plugged in and there is fuel getting to the rail. I am starting to think it is of 2 things.
1. there is no spark. because i have tried advancing and retarding the cas and no difference. and i can hear the injectors pulsing.
2. I have buggered up the injector firing order while making the new injector loom. this wil be a bastard to diagnose and will mean pulling off the plenum again.
I will make sure i am getting spark tonight.
also battery would be going flat but seems to turn over the motor fine. I am sure it is something silly. it will get there.
Also how long should you have to turn over the motor with ignition disconnected to get oil pressure?
who knows...pull off your oil feed line to the turbo and let it spit into a bucket for a while and then hook it back up. Once it spits abit out of the line there should be oil pretty well everywhere else. It doesnt take long for it to work its way through the motor.
may sound silly but a similair thing happened to me on my first start up that cubes will remember, haha!
It just turned out that my fuel lines were the wrong way round where they connect near the plenum!
HAHAH ive done that before :thumbsup:
Dash lights are all on when cranking?
you can also try the carbie cleaner trick in the TB then crank, if it coughs like it wants to start, then you have no fuel and do have spark.
Well she is in and running :thumbsup:
rough as guts but running...
mr rbman you my friend are owed beers :(
just before you posted this this afternoon I looked at an RB photo and realized exactly what i had done. I then had to sit at work and look interested for the next 3 hours...
race home swap them over and ALIVE! it will not hold an idle and misses loke no tomorrow but it is running. tuning and testing will commence in a few days :) I have had enough for now
haha, thought your problem sounded far too familiar!
Well she is in and running :)
race home swap them over and ALIVE! it will not hold an idle and misses loke no tomorrow but it is running. tuning and testing will commence in a few days :D I have had enough for now
I have a question re CP Pistons.
I know they are off the shelf ones available for the 26/30 combo...
Is there anyway that these can be customised to tolerate high horsepower / boost applications? I am going to more than likely get a set with a 22mm pin diameter. I've read that the rings can be moved down on the piston for high boost. Can someone give me some info about getting a set custom made?
Also, dry sumps. Has anyone bought a dry sump for the RB30 motor? If so, where did you get it from and how much was it?
CP will make one off custom sets to order - the price is considerably more.
You must be planning to make an immense amount of power as there are a lot of off the shelf CP's out there making spastic power.
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
