Yep it's been a while.. I just wanted everything to be done :P
Basic run down on my setup currently:
Stock RB30 bottom end (new bearings, rings etc)
Ported RB26DETT Head with mild cams
Subzero Split pulse manifold. Used a plate to fit my current turbo.
Garret GT30/40 spec turbo .82A/R Rear
600cc injectors
Power FC
A guy here in Brisbane does them,NV N01, as well as HICAS bars. Pretty good prices and good products hence I don't do the bars anymore.
Al, just loosen everything, drop the front of the cradle down after removing the lower pineapples and put the split ones above the cradle at the front. You only use 4 at a time. you will need a bar to lever the cradle down far enough to install mate. Better yet get the Alloys. I could feel the rear of the GTR squirming with the pineapples and now there is too much grip with the Alloys for skidpan work. I can only assume the cradle bushes were pretty doughy and the pineapples not enough to help it.
What you will notice is a bit of drop in the rear when accelerating hard but no other real issues.
Ben I saw your dyno chart. An extra 70rwkw at 80kmh. Pretty nice.
Haha that's great to here, I have a max oversize slide hi-flow too. Can't wait to get my rb30 back together.
What tyres/rims are you running? also what manifolds are you using?
I have a set of fedral 595's 235/50/17 and 9" rears. I am going to get 265's when the ones on there are ready to be replaced. also will get the camber set to 0deg.
stock manifolds :P conservative timing and fairly rich tune ( 11.5:1 )
its a really touchy combination of turbo and engine. especially with a 2 way lsd, anything more that slight throttle around a corner and it will start to slide.
the alloy bushes hold the cradle still but not sure if they are the best setup. if i was to do it again i would replace the stockers with urethane items.
So i've gone back to the idea of dry sumping the motor and this is what i've came up with...
Feedback is welcome.
1. Peterson 4 stage dry sump pump, left hand mounted
2. Oil filter
3. Modify rear of head to have external oil drain (unsure if needed, would use 3 stage pump if its not)
4. Two pick up points from dry sump pan
5. Oil cooler
6. 1.5 gallon / 2 gallon oil tank
7. Remote breather can
Any suggestions or pointers? I am not too sure about the external oil drain on the head, if its required or not on a dry sump setup. I thought if it was then a 4 stage pump would be required so I could have 3 pick ups ( 2 from oil pan and 1 from head).
Has anyone used a Davies Craig electric water pump for their build?
My mate is using one on his 302 windsor. I was a bit skeptical when the Idea came up, But its really working great. actually better than the Mechanical Stock pump did. We also have a DAvis craig 15" thermo fan setup, with thermo switch active on it, so that also helps. the damn thing runs cooler than my RB. so yea. good investment. But not sure if its really worth the effort on an RB.
I would put the oil cooler inline after the filter before the oil enters the engine. Ideally you would have a cooler before engine, and then one before it goes to the tank.
We are having success with our dry sump set up so far with 3/4 of the season complete.
3 scavenges from the sump, none from head, oil pumps through cooler to filter to motor and back to tank after going through an in line filter before landing in the tank. Tank holds about 15 litres of oil (Redline ouch $$).
Biggest and most difficult job was fabricating the bracket on the Left side of motor and arranging for a machine shop to modify the harmonic balancer to add the pulley wheel.
Good luck...the peace of mind is brilliant and with the vacuum created we seem to have almost solved the top end oil problems even when the car does a 15 lap flat out race.
2. Oil filter
5. Oil cooler
I'd put the cooler on the pressure side between the pump and the engine. I suppose you could run both sides but it makes for a lot of extra plumbing.
so... is that solid works or autocad you used to draw that up? :laughing-smiley-014:
I have to admit having three pick ups from the sump and none from the back of the head is alot easier and tidier. But if you had the head return already from a wet sump setup and converting to dry sump, rather then removing it, it can be simplier just to connect that line to one of the scavenges.
Either way works fine, it just depends on preference i guess. I believe peterson suggest two coolers as the ideal option, one before motor and one after. I would also filter the oil before it goes to the cooler, helps stop any crap from getting caught up in it, as they are pretty well impossible to get perfectly clean.
Ive said it before...but make sure you use the inline filters on every scavenge point! Thats a must, if you dont want to do it, refer back to my ballbearing in peterson pump gear thread.
I might as well use a 3 stage pump seeing that I haven't put an outlet /pickup on the back of the head.
Its my understanding that I wont have to put a restrictor in the oil galleries right?
Proengines - Photoshop CS3 autocad. lol... you like?
r33_racer - I sent you a PM re oil pan.
what do you guys think about remote oil filters?
if i was to use a remote oil filter on my rb30 with n1 pump, 1.5 mm head ristriction and the other blocked off, is there more chance of things to go wrong in the oil department??
the remote filter is just for practicality and does nothing else, so would this increase likelihood of oil starvation to head??
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
