Long motor includes bottom end and head and all internal parts but no accessories.
short motor is same as above minus the head, includes internal parts inside the block and sump.
It's obvious what you need for the det conversion.
ahh cheers thanks man jst what i needed to know
Does anyone know if you can use the High energy 7L sump and still retain the factory stone guard in a 32 GTST?
Also noticed that the drain plug is on the opposite side to factory.
http://www.skylinesaustralia.com/forums/in...t&id=140593
Edited by Alf
anyone had their crank nitrated? The shop rang me and asked if i wanted it done since the whole bottom end is getting blueprinted. Cost me $900 though! I want a tough realiable engine and am cutting no corners using argo rods, jun oil pump and ati balancer. Ive been told the block is weaker then rb26's. What can i do to strengthen it? Resin fill? Can someone shed some more light on this?
cheers
cheers
All RB cranks are nitrided standard.
Cheers
Gary
Hey all,
Just want to know what you guys did for the oil squirters did you put them in or not?
Bitch of a job, not all blocks will accept the threads and you can't tell until you start machining. S1, S2, Commodore, Skyline and turbo blocks, makes no difference, about 1 in 10 will take squirters. So we stopped fitting them about 60 RB30's ago, we machine oil squirters into the conrods, works perfectly. For heavy duty applications (over 750 bhp) we ceramic coat the piston crowns and oil retention coat the skirts.
Cheers
Gary
Is the $900 quote just for the nitriding ? or all the machining ? ( bore, hone, crank grind etc )
cheers
Hi Gary
When you say " we machine oil squirters into the conrods " are you referring to what is used in the OEM rod. A oil feed hole in the rod that sprays up under the crown fed from the big end ?
Cheers
Gary
Could someone explain the process of nitrating for me? If all rb cranks come like that standard then why the heck they suggested it? Since the rb30 crank is fairly old, could it do with a re-doing? I was quoted 900 for nitrate alone and 2100 for bore, hone, grind etc.
I also got my pistons ceramic coated. far easiler then trying to get oil squiters i was told.
guys this is probably the best posting i have seen on anything technical..
anyway im about to start a build on my 31 with a 25/30 and wanna make 300 kw atw...
can someone do me a huge favor as i get confused with trying to follow the posts and give me a guide on parts to use... i have a series2 rb30 in my car so the bottom end is started but wat else do i need to achieve this without it melting down on me...
cheers...
Damn that sounds really expensive!
Hope they are not taking advantage of your ignorance :D
You can order the sump to gave the drain plug on the other side.
I made a custom order for mine to have two "-10" fittings for the oil returns (one on each side), one oil temp sensor fitting and something else i have forgotten. The mods were done perfectly and placed in the idea places.
cheers...
first page there is a pdf you can download. covers allot of things.
Hoang, they are absolutely ripping you off mate.
Nitriding is a process of introducing elements through heat and proximity to create a different alloy near the surface of steels in order to prevent crack propagation and sub surface crack nucleation. It can never wear our as it is now alloyed in the structure. Redoing it is basically useless as the nitriding resists further nitriding. To remove it you need to machine away the surface material.
My bottom end machining, cleaning ready to assemble and head skim with full zero balance cost $1400.
gt35, low mount cast manifold, external gate... possible? don't think so but i like to dream. keep them cops eyes at bay.
If you were running a GTR head then the old HKS manifold for the T04R means that would woudl likely be able to do this dependant on the turbo flange as the hKS manifold is a T4.
Not sure about R34's, but on the 33's the hks manifold and GT30R or GT35R will hit the engine mounts.
Matt had problems because of the turbo size is bigger then the T04E that the kit normally runs. Its strange because the turbo he runs (3076) will fit on an R32 with RB20 (Legend01) and has been used on several RB30s. So the extrea deck height of the block will most likely get you ouf of troubel with clashes with engine mounts
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
