Here are the pics for the water gallery mod. Some people dont do it but I dont like to rely on the thin bit of gasket to seal.
So pic 1 shows the std RB25 head, Pic 2 shows the std RB25 head with a RB30 gasket fitted, and Pic 3 shows that the RB30 gasket just covers the water gallery in the RB25 head by a few mm ( see the black Nikko Pen line )
I have the hole welded up ( and the oil gallery hole ) and reshaped to the same size as the RB30 hole so that the gasket fits perfectly.
Edited by Spoolup
OMG!!!!! LEGEND :banana::)
Finally somebody who understands what I was trying to get at, and hopefully now people can understand that I wasn't asking a repeatadly asked question about VCT.
Cheers mate, that's helped alot!
Jack
i remember reading somewhere about what bluegts is asking - someone welded steel onto the Block arounda water gallery then had it decked - apparantly there was only a small amount of overlap between the water gallery and the edge of the block..
OMG!!!!! LEGEND :wub::banana:
Jack
As im using the rb25 gasket i'll prob be doing to the opposite of what spoolup has shown
Does anyone know if there is an "off the shelf" MLS headgasket thicker than 0.074 (1.9mm) for a RB30 or RB26?
ACL, Nengun and Greenline's thickest are 0.051 (1.3mm), Cometic make a 0.074 for the RB30ET ( will suit my mod'd 25 head).
Trying to get the comp down to 9:1
Last resort is to go custom. :wub:
Edited by Alf
I would measure the crown thickness, and be very tempted to machine some of the crown off, its a cheap job on a lathe, and will get you away from the horrid squish you are going to encounter with a "decompression plate". PS you can run 2 gaskets.
aaaannnnddd a snip from the rb30det guide if u looked at it like I said. :wub:
shows the same thing side by side. You can see where the differences are and what needs to be modified.
Yeah I've read your guide so many times its not funny, but it didn't mention anything about reshaping the water gallery thats why I got confused. It states 'how they need to be modified' and I just assumed that was refering to the mod required to block the VCT oil feed. Cheers anyway, I'm all good now :banana:
Jack
hows it going guys.
cars finally doing the final tune, but we are having massive boost isssues.
the car is making over 300rwkw at 4000rpm but just cannot hold boost. set boost off so it runs off the gate (.9 bar) and it just keeps climbing.
heres the current setup
3.0L
gt3540 .82 housing
44mm tial gate with .9bar spring
exhaust 3.5" to cat then 3" all the way
ive started a thread in the main FI area. any help in here is greately appreciated aswell.
http://www.skylinesaustralia.com/forums/Hu...ep-t215455.html
44mm gate is big enough right?
we are currently in the mist of dc the gate to find out if it will make any boost. if it dosnt then the gate is fine.
some ppl think it might be the dump pipe being to big? (3.5" to cat then 3" all the way)
lastly it might be a faulty manifold?
any help appreciated
Edited by R34NRG
Random thing to try...
T-Piece a boost gauge in JUST before the pressure line enters the wastegate.
See what boost it's seeing down there.
Waste gate may not be connected properly pressure source wise.
Now for my question...
I have an RB30DET in my car.
Had some issues getting it to crank.
Had to pull timing belt off etc. Check to make sure cams would turn etc...
Stupidly, I made ZERO markings, and now need to know, HOW do I get the timing belt back on in the right position now that I have everything sorted out.
I know I need to pull the harmonic balancer back off and have a good look down there... BUT, how can I get the timing belt back on correctly, since everything has been spun independant of other things?
Matt, just make sure your timing marks on the cam gears and the cam drive gear are aligned properly. There is a notch in the oil pump housing for alignment of the drive and marks on the outside of the cam gear backing plate to align the cams. Get them aligned, slip the cam belt on keeping the right side as you look at it tight then adjust the tension. Check again that all the alignment marks are properly lined up and then wind over the engine 2 turn clockwise as you look at it by hand and check again, then if all is aligned properly re-tension the cam belt.
Hey, first post here. I currently own an SR20, yes very torquey engine and i love it.. when its reliable (drifting). I had ideas floating around about 1j's, 25's blah blah but then a mate got me onto this idea of the 30/25 setup, i liked it so much that im picking up and engine this week. Im up to page 55 in this thread (2 tabs open) and i plan on going through the whole lot. What i want to know for now just to get more of an idea is where the RB30DET guide that Cubes i think has made? If someone could lead me to that id be much appreciative. Also after reading 55 pages the thing im still stuck on is whether to keep VCT and what CR are best? I can get my hands on a RB25DET head complete for relatively cheap to..
Go to the very first post in the thread.
There's a link at the bottom of the first post.
Open it. Then there's al ink to the DOHC guide.
Also read Cobra's
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
