Not sure if this has been mentioned...
I recently got my RB25/30 running (last Tuesday). I did the mod for the VCT, however, all I did was grub screw the hole in the head, with no other modification. My VCT works perfect. No oil control/lack of oil issues or anything (this was mod was done on the advice of my engine builder).
Discuss.
u mean to say u didnt do either internal(from buckets) or external oil feed to the VCT solenoid and it still works??
Correct. All I did was the grub screw mod to stop oil/water mixing. Bolted the head on (of course all of this on the advice of engine builder) and it works fine. This has been done on my mates twin came RB30 and his also works.
quick question guys, got a 6boost high mount mani and a gt35r turbo,did anyone have to re -postion any of the front or rear housings on the turbo to position the turbo correctly on the mani.my mani is a t3 flange,fits perfetly,so no problem there!
yes you will need to losen the front housing so you can align it properly with where you want it.
make sure the oil feed into the turbo is facing straight up
thought so cheers!i wont be doing it,just a stupid ? really, but there is no stupid ? on here!
ive just gotten hold of a NA rb30 bottom end and gonna to the usual build, ie rods pistons and so on, just wonder a few things...
1. is there any difference with the rb30 NA and Turbo Crank
2. can the rb30 crank be fitted to a rb25 block to get around drilling and taping holes in the rb30 block, read somewhere that this was possible and if not what is the best way about doing the tensioner for the belt if the pre tapped hole is not there.
3. is there any other differences between the turbo and NA rb30 block itself.
Using a 25 head, cheers for any help :)
Edited by fomby639
no
no
no, but there is a small difference between S1 and S2 blocks in relation to the flat area where the tensioner goes, the S2 block is a little easier.
Using a 25 head, cheers for any help ;)
Cheers
Gary
Some of the S1 blocks don't have the turbo oil feed drilled all the way through, check it with a piece of wire and make sure it goes all the way through the block and into the gallery behind the oil filter housing. You can drill it, just need a long series drill to do it. I've only seen one block like that but it's worth a check.
hey guys! Sorry its been a while have been so caught up with work and studies haven't really had much time to spend online or on cars sadly :banana: But i have managed to FINALLY get mine trouble free and tuned. How is all the rb30's out there? Hope all is going well for the festive season.
On a quick note has anyone has issues with the speedometer drive/cable on the bigger rb25det gearbox? For some reason my gearbox keeps shredding the plastic part at the end of the drive, It was all fine until i took it out onto the open road sitting around 100km this is the second time its happened and was wondering if someone knew a way around it?
do most of you guys get more area welded onto the head on the front water gallery i think it is how its different from the rb30 block? i got my head rebuilt but didnt know about getting that bit modded to get more gasket sealing area there. will it be ok to leave it how it is?
its a rb25det head from a r33
Edited by joe blo
How closely are you following the writeups for the speedo sender? are you cutting a new groove and rotating the sender 180'?
too be honest i didnt know there was one lol. Um i was thinking maybe it was because of the bigger motor it was doing this? I have yet to pull the speedo drive out a second time to confirm that it has chewed the plast gears, cutting groove and rotating???? I'm not aware of this
Read the writeups!!
You basically need to rotate the sender 180 deg otherwise the gear mesh is too great and it chews the gears out.
  • 3 weeks later...
hey people, great thread this one has been a great read!!!!
i am just about to do the following
put series 2 stock rb30 bottom end, with new bearings and piston rings
onto a stock series rb25 head.
how much should i be charged for this in labour? i have benn qouted $2500 nearly $3000
bear in mind this is to keep vvt also
any help and advice on whethter this labour price is good please let me know, i think its way too much
Guys I was just doing some casual reading AGAIN on the RB30DOHC guide, and in relation tot heR33 RB25 head, it claims you will need to:
"The R33 RB25 also requires you to plumb in an external head oil return, you can T in to the turbo drain."
What is the external head oil return it speaks of? Is this the standard one at the front of the head that needs to be T'd in?
I'm on my second RB30DOHC motor, and never had this fitted... What issues are normally seen if this isn't plumbed in?
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
