As some people know i am working on dropping the RB30det i had in the Black R32 gts-t into a R32 gts4 with 4WD. The motor is just about ready to drop in, Just thought i'd share a few pics of the exhaust manifold i built to low mount my GT3540.
Edited by sky30
https://www.sau.com.au/forums/topic/154768-my-rb30det-into-gts4-build/
  • Replies 49
Posted Images
Very nice... :(
Got any pics of the the exh. manifold with its heatshield on?
Did you manage to get the stock heat shield fitted with a bit of manipulation or are you going to make one up?
If the stock heat shield fits its going to look almost invisible. :laugh:
good stuff carlos.
might be down next weekend
Bring your car cozza, take us for a ride, you had it back on a chasis dyno yet?
Joel:- I had a stock RB25 n/a heat sheild i bent up to make it fit. The RB25 n/a shield has thick white blanket material on the underside which should work good. I see if i got sum pics.
would of by now but thats to an engineering company in qld i now have a bend valve and a couple of chips in my piston, the collet pulled through them billet retainers on weekend. so am going through the legal process of getting it repaired. which could take some time.
Had street machine magizine ask for photo shoot on weekend too. :thumbsup:
26 head this time???, cams??, be a good sleeper this one
cheers
darren
Darren, yeah i went 26head this time for the solid lifters to allow bigger cams and the better GTR plenum.
The aim is to keep it all looking stock, similar to my black R32.
NICE!! - Would like to do this to my GTS4 as well. Maybe later this year.
Like the stealth idea with the heat shields etc.
Can you get to those Cam Cover screws?
My HKS Tubular intake makes it damn hard but possible.
Like the full polished look as well, looks trick.
What sort of price would a manifold like that be worth to buy from you?
Had street machine magizine ask for photo shoot on weekend too. :blink:
Geez... how did you manage that... lol... Long time no see, hope all is well. Wanna see the beast again :P
Geez... how did you manage that... lol... Long time no see, hope all is well. Wanna see the beast again :blink:
If it helps, blew a tyre last night doing the speed limit funny enough on the new front left tyre. Ended up with alot of hours lost, damaged radiator hoses, thermo fan had to be repositioned and wiring re-done, and exhaust re-heated and put back into shape (that was from the trailor).
Miss ya on the cruises mate, hope to catchya soon, and if you manage the photoshoot this weekend enjoy :P
Ash:- yeah, getting close, still got cams here (sitting in cupboard), just havent been to adelaide for about 6 months.
Joel:- head is only temporary bolted on ( havent done final assembly), i have blocked off the rear oil feed with a screw i made, i may be interested in that restrictor. what do you think i should run 1.8 or 1.5mm oil feed at front and rear blocked??
Joel:- I thought the 1- 1.2mm were for those running GTR or N1 oil pump, im only using a std RB20det pump, thats why i thought id stick with 1.8mm, or 1.5mm.
Are RB20det pumps same or nat as much flow as RB25det pumps?
Do RB30 blocks come std with 1.8mm restrictors??
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
