After many many years of wearing bloody helmets it all comes down to you. Not every brand of helmet will fit you properly. Chicks get it a lot easier because of the lack of a protruding adams apple. I would suggest picking a budget,,,adding 300 bucks and go try heaps of them on. You will known straight away as soon as you put it on and tighten it up if it right for you.
For the record I have owned Simpson, AGV's, Arai's,,,cheap crap and am now wearing a Bell Vortex Ultra which is light and comfy.
My wife made me spend so much money on it,,,I get nervous when the scutineer has it in his hands.
Remember try heaps of them on and don't just go to bike shops and Revolution,,,try some other motorsport shops. I did buy mine from Rev but I was lucky as it was on special.
Neil.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2920276
  • Replies 85
Hmm, interesting. I cannot fault my Jet 2 for quality, so am not quite sure what you mean by that. It fits me nice but then again everyones head is a different shape.
The Jet F is a more recent model than the Jet 2 hence the availability of Hans pegs.
Make sure when they turn up that you look inside to see the safety code the helmet complies to. It will either be SA00 or SA05. If it is SA00 hammer them on price because it will be old stock. The helmet is still perfectly compliant and useable, however.
sorry not quality but shell design different. yep mine is a SA05.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2921705
:) Mine's a HJC cl14, only a cheapy to get started, but is snell,dot & aust. standard approved.
Fairly light, nice & comfy & is suited to my big noggin.An american company, that's why they make 'em for big heads apparently!
At around $250-300 i think good value for money & really happy with it so far.Plenty of plain colours & graphic styles to choose from...
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2923844
After all is said and done, its a helmet. designed to keed up your head from looking like a busted watermelon in an accident. Try (if you can) to get the very highest quality you can afford, ask yourself.. what is your head worth to you?
Bear in mind that some motoring organisations require a set standard of hemet. make sure u exceed this standard and check out what other motoring bodies use as their standard. You never know when you may want to try something different with a mate or something..
You don't want to be stuck in a situation where your helmet is the only thing stopping you from doin somethin new! Even though it is a great helmet..
any other thoughts.. :(
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2930849
I agree with what you said psi. I would spend as much on the helmet as I can afford. You see people go off and spend 5k on car mods, then be stingy and pick up a helmet for $100. Is your head only worth $100? It must be if you're that stingy to spend that little on it.
Keep in mind that if you are collided from side on, your head WILL hit the window. Head bashing window = bad.
I'd much rather have a good helment protecting my fricken head, than some cheap arse one.
If you've spent 5k plus on car mods, I don't see why a helment worth anything up to 500$ isn't too much
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2930872
Just to disagree with everyone, I just buy cheap and well fitting. Under $200 for me.
Its nice to say "if you have a $2 head buy a $2 helmet", but don't forget even the cheaper helmets are AS approved, and I've never heard of someone who died wearing a cheaper AS helmet who would have lived with a $1k lightwieght super stig helmet
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2944821
Fair enough Duncan, as you say, cheaper helmets MEET the required standard, but I am one to assume that more expensive helmets (discarding the fact that in many instances, you are no doubt paying a large portion for a "big name"), not only meet, but EXCEED the required standard.
Another issue to keep in mind is that a lighter helmet has less kinetic energy in an accident, therfore there is less chance of neck over-extension damage, particularly in a frontal impact situation.
Cheers!
(p.s. not long 'til TARGA!!) :P
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2944858
so what helmet are you using? :P
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2945174
very good point. and is the reason I bought the cheapest carbon/kevlar helmet I could get. it's around 1kg. :ninja:
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2945189
You buy cheap cause you are cheap. I remember you cost me like 2 bucks the other night. 2 buck helmet for a 2 buck head.
There's no way you can convince me a cheap crap helmet is as safe as a high quality one and neither is the fit or quality of the lining. I'll be interested to see what helmets you buy next seeing as how your current ones are just plain tragic.
Neil.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2948691
absolute rubbish. In fact the only reason I am getting a new one is because I didn't have a helmet bag for the first few years and I scratched the crap out of the outside.
It has been used heaps, still fits well, no trim coming off etc.
And like I said I will be going back to a motorcycle shop and picking whatever is cheap and comfortable again.
https://www.sau.com.au/forums/topic/156168-helmets/page/2/#findComment-2963128
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
