Dont drive a totally unroadworthy car then :thumbsup:
Myself and another forum member have both been to the EPA in the last 3 weeks, separate days.
No police in sight.
They are probably there to serve notice to repeat offenders.
hey, just wondering if anyone has any information to share about getting a car retested for emission in one of those special labs. Im after information like who does it? can you get the car tested somewhere prior to paying $1500+ for them to test it?
Pretty much any info will be helpful.
Thanks, Mike.
The full ECU based testing i think is a bit more than 1500 isnt it?
You might be able to find somewhere, best bet would be ring the EPA themselves.
But it wont be cheap as that equipment costs a bomb, and hence they charge accordingly
The only car I know that has been totally certified for emissions is BLKCRX (James), and he had to go to the labs at the Ford factory in Geelong. I'm not sure of the specifics but I know it was very pricey. He can be contacted through the CRX OzHonda forums.
Hope that helps.
Edited by stolen_s15
  • 4 weeks later...
hey guys cops got me today epa time.
so wats the go, i get a letter and gotta bring it in, do i get a fine for this at all?
am i gonna be in shit because parts of my front bodykit has been cut for front mount>>??
any tips guys??
nope that has nothing to do with epa, thats for a defect and will need an engineers cerftificate but that will be on the defect notice if you got done for....That still has nothing to do with EPA
EPA is all engine/exhaust related and to do with teh emissions from the car :P
oh ok so that will be ok then.
this is my first time for epa.
they didnt give me any notices just said that vic roads will send me a letter in the mail about when to go and get everything checked.
so yeh he was saying about the whole cut but he didnt give me anything for it? or will all that be on the letter that commes out.
hmmm not to sure about that never had it happen for me, but id say if they do you for the whole they have to have it on the defect notice im pretty sure...
and EPA could be just a noise test which would require you to change ur exhaust to stock
or a full test which means car pretty much has to go back to stock :P
  • 4 weeks later...
Yeah so I got a "random" EPA fine - long story but basically he crossed 3 lanes of traffic and moved up about 6 cars to get me, no I wasn't doing anything wrong either. Not Happy Jan.
I was asked to pop the hood, he noted the pod and intercooler then mentioned that the EPA would send me a letter.
Is it likely that it will be a full emissions test? or just the exhaust (i'm confident I'd pass the exhaust).
But I have a secondary question - I don't have the time, tools nor stock parts (I have an ECU, EBC, Pod, FMIC and Exhaust) to continually pass this kind of thing.
If I was to buy a Stock R33 GTR, Do the Exhaust, FMIC (Use a K&N Filter rather than pods) and possibly the ECU thing (altho keeping the stock ECU for "times of need") would I pass by default assuming the exhaust was of "legal volume". If not, what *could* i do to a GTR and pass consistently (thus not having to f**k about with mechanics etc)?
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
