Out of curiosity, does anyone know if aftermarket 4WD controllers are legal?
I have not read a law against them (yet) but I'm sure the police may find one if necessary.
Does anyone know a law against adjusting the AWD system in your vehicle using an electronic device?
i got a defect for being to low , on the paper it said adjust it a little more higher thats it. he ticked the box RWC required and it was a minor. Now would i need to go to a workshop and get a RWC or do i just adjust the hieght at home then go to VIC roads and get them to check?
Thanks.
Geraus.
i believe if you change the rails yes
and a fixed back requires engineers also - as you legally have to re-rego it as a 2-seater only - and if you get busted with people in the backseat - god help you :P
They dont care, and for good reason.
In an event of an accident on the passenger side - how do people get out of the drivers?
Its purely a safety thing, and honestly something i very much agree with.
quick question re seats - and sorry I haven't read entire thread only the last little bit cause we're on the topic of seats sorta anyways:
I've removed my rear seats years ago to replace with mdf/fibreglass/multimedia etc and spent a day on the phones chasing around requirements. Finally, the answer was that if i didn't change the metal/structure/parcelshelf or anything existing, then i didn't need an engineers certificate. People have told me i need to re-register but I never have and have been pulled over by cops up to 6 times already this year but nothing, nobody says anything.
do i speak to vic roads before rego is due next time, or remain how is as it can be changed back and not permanent? has it got something to do with the seatbelts if they are removed or not?
Thanks.
Got defected twice this weekend :P one for tyres being a bit too bald and the other for blue parkers. I copped a major for the tyres with RWC needed. Now my car will pass easily except for one thing... is it un-roadworthy to not have a fan shroud? Should i hide my boost controller somewhere? or is that only an EPA thing?
Hi,
I did a search but can't seem to find an exact answer to my questions.
I'm looking at buying a skyline from NSW. The car would have a NSW RWC with it.
1. What do I need to get it registered in my name in VIC?
2. Do I need to get a VIC RWC again?
3. Also, since the car is not rego-ed in VIC, when driving back from NSW with an NSW rego, do I need to apply for temp rego from Vicroads?
4. What should I be getting from the seller in NSW? i.e. What kind of documents?
Sorry for these questions as I'll be relocating to melbourne for work come end June. Thank you.
Hi,
I'm looking at buying a skyline from NSW. The car would have a NSW RWC with it. - If you're going to transfer the rego to Victoria, I wouldn't bother getting NSW one.
1. What do I need to get it registered in my name in VIC? See below.
2. Do I need to get a VIC RWC again? Yes you do need to obtain RWC in Victoria.
3. Also, since the car is not rego-ed in VIC, when driving back from NSW with an NSW rego, do I need to apply for temp rego from Vicroads? Just drive around until you get Victorian RWC and go to Vicroads to swap the plates over.
4. What should I be getting from the seller in NSW? i.e. What kind of documents? You'll need some sort of ownership transfer form and possibly receipt for stamp duty (not 100% but Vicroads site should cover this).
See bold text for answers.
Hope it helps and good luck.
Cheers
Cheers
Thanks mate.
Just another quick question:
If I still need to obtain another RWC in VIC, the RWC in NSW is not really needed right? ---> was that what you meant in your answer to my first question?
cheers
Edited by meowdog
Thanks mate.
cheers
Yes, if you're going to register it in VIC, what is the point of getting NSW cos they're different (all state of Australia have different laws in Roadworthy).
Another reason to bargain the price down a bit.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
