Tried them on RB's? :ermm:
To get to a 90dB limit for the EPA, a resonator will not get you over the line - that was more the point i was trying to make. So a rephrase of my statement if i may :)
Also remember 2.5" will flow any reasonable amount of power as well (2.5" is not a friend of a modified turbo setup).
Ok if your only chasing 200rwkw, but if you are looking to 250-300rwkw and beyond you are in a very big pickle on PULP.
edit: (talking about a system you can run daily, not swap out for EPA only)
Tried resonators on RB's? Yep. Rb's are great, because they are easier to shut up due to the smaller cylinder capacity (SR20 = 500cc per cylinder, RB26 = 433cc per cylinder, therefore pulses are less in amplitude. A resonator will get you over the line, but it depends on the outer diameter, the packing/hole size and the length. Have a look at the "Helmholtz resonator" and how they work. It's an excellent method of removing exhaust energy with minimal restriction to the exhaust system. Some work and some don't. It depends on the quality and if the exhaust shop knows what they are doing.
The fitment of a quality resonator WILL lower your sound output on your car with minimal restriction. Fitment of an absorption muffler is a larger resonator. Fitment of a reflective muffler will lower your sound even more, but will provide more back pressure.
For the SR20, the fitment of the resonator that I made was a permanent fixture. I value my and others hearing.
Hey guys,
Got defected last night for:
-Manual Boost Controller in engine bay
- HID headlights with 'no washers.'
The cop was a prick, "I wont defect you for the air pods."
Me "Because they're legal mate."
I think he is right with the boost controller and HID's but?
Sigh.
Are they china HID's?
Id imagine so, so yes, they are. Philips i think is legal, but they are expensive hence no-one has them which is kinda silly given the price neutrals the defects
Yeah they are some Chinese brand.
I didn't even know about the Philips ones.
Also manual boost controller....not rw?
i thought hids were legal but legal limit was 6000 or 8000k??? i think 6000k.
btw got rwc & cleared defect on friday arbo..feels good to be back in the 33.
just got epa to worry about..only due end of august though.
n thanks to everyone for the advice.
Any after market boost controller is illegal. If cops see something that is a different colour, or something that doesn't look 'factory' it's game over. So either put it back to factory, or hide it and hide it well.
The reason an aftermarket boost controller is illegal is because it changes the 'factory' emissions.
Maybe when you got the rwc they didnt look for or find the hid ballasts or anything. Any HID is illegal if it does not have auto-leveling or a water jet cleaner for the headlight lense.
Currently any HID is illegal if it is aftermarket and not complianced as factory with the car. You cannot fit HID's to your car without them being factory fitted to your model. The reasoning behind this is because you are not in a position to interpret the ADR requirements whereas the automotive engineer/car designers are.
okay just paid epa fine arghhhh $584.what a waste.
but still got to fix exhaust. spoke to a exhaust place and they said something about making a flange or something and quieting it down for $150. Was just wondering if i decide to leave this in would it effect performance or anything?? and if i take it out and get caught again will i have to pay another $584? otherwise i may aswel try and find a quieter muffler and do it properly.
or i was thinking of borrowing & putting a stock 33 exhaust back on to pass epa until i know what im going to do about the exhaust.
i have a silencer at home which i could just have welded on but it sounds all sh*% with them lol.
yeah it will benefit me in the long run to do it properly, and that goes for everything and any problem anyone has i guess.
probably just going to get rid of the cannon and put twin pipe muffler on it. just need to find one that still sounds nice but not to loud.
guy i spoke to from dandy exhaust reccomended a magna flow one so ima go down n check it out.
or theres these for $65??? not too sure on them though
What is the current exhaust setup?
To get past the EPA you'll need more than just a rear muffler (& cat).
You'll need a nice sized mid muffler too, infact the mid one is more important as it'll be larger than the rear one
(if memory serves me correct you can fit a larger one in the middle on the R33s)
Ye, one muffler isn't going to get you over the line, i was in a similar predicament and i'm not N/A!
I honestly feel you are gouing to need two very decent mufflers to pass the EPA.
You dont have a turbo to knock out some of the noise which is not helping.
Any by decent i mean more much than a $65 muffler :(
Go down and have a chat to a local exhaust place, there are a few good places Vic people use (if you have a search)
Just do what i did Beau, My exhaust system is a full 3 inch with only a cat and muffler. When i get epad i have a custom pea shooter rear muffler which i chuck on which goes down to 2 and a 1/4 inch. Passed EPA with the full turboback 3 inch to that muffler, with only a cat and got 87db.
Know you have passed it now but me spending $150 on that muffler saved me 3 times already :D
You do know they have now started taking photo's of just about everyone?
That trick wont work forever, recently a few people have been slapped with some fairly hefty fines i've heard around the traps.
Being they have been busted swapping mufflers over and so on.
Now more than ever, do it right
When i went to get the epa done they only took pics of my engine bay and cooler.
Technically on paper my exhaust system looks the same with the pea shooter and with the cannon. Thing is i can always say i had the small muffler on when caught, thats if the cop doesnt take a pic of it on the spot. They cant prove it.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
