Got my roadworthy today. Much better than previous place, just had to change the tint on the front windows and get rid of the pfc controller.
Where did you get it done?? Or has anybody got a place that is slightly lenient on us??
heres an interesting question
the car i purchased came with a roady (was less than 30 days ago)
Over the past week ive noticed that there has been an oil leak or two off the bottom of the engine. the main leak is coming from the sump plug hole. Replaced the sump plug in the hope that it was the problem, but it still seams to be leaking. there also seems to be another oil leak, but im unsure where it is.
now here is the question lol
isnt the roady supposed to pick up on such things as oil leaks?
if this is the fact, is there recourse against the shop that issued the roadworthy to fix these problems because they missed them/overlooked such issues?
cheers
They are not meant to sign of a rwc if car has oil leaks...a rwc is valid for 30 days from date issued...if I were you id take the car with the cert back before the 30 days is up, you might have a good chance to get it fixed free of charge.
thats what i thought.
however im not a fan of good chances, id rather a full chance
A leak can develop after the RWC is supplied.
You'd have to prove beyond reasonable doube it was there when the cert was signed.
thats what i was worried about.
would the oil/grime caked onto the sump prove?
any other way i could prove it?
From what ive always thought, a rwc check doesnt actually fix any problems if they arise, they only note them down. So if you go in there with leaks they might cancel the certificate and get you to fix them (at your cost) before they will certify it again.
Davey32 you have a PM.
lol
don't like your chances unfortunately, cant hurt to ask but they will be on the defence straight off since your basically saying to them they are in the wrong.. often doesnt go down well
Problem is unless you take a photo of anything wrong straight after buying the car they will just say 'oh that happened after', i'm not talking about really bad stuff like cracked screen or bald tyres, but things like oil leaks or whatever they can be cleaned of for the roady and then start leaking after a few days, no way you can prove otherwise.
i got epa'd, stupid thing is, when they said I was "spotted", I was at work, and my car in the work parking. i didnt even drive through the place.
I've had it cleared but wtf are these idiots doing.
same thing happened to me, apparently i was driving on a monday night at 12am about 2 weeks before i was heading overseas
thing is i was asleep because we were busy trying to finish off as much work as possible before i left
problem is you cant contest it because they will still say test the car and prove its not to loud etc
Couldn't you contest it with a factory exhaust? Assuming of course it was on at the time.
they would still ask for you to test it though, thats the thing... there is no point in contesting
at the time i had my old exhaust on anyway, a lot louder than whats on now but thats not the point
i was stung even when i wasnt driving :(
That's gay that you can get your car epa'd when parked.
Though I woulda thought the wagon would of been safe :ninja:
It is generally safe but we are in Vic, if it's anything to up their commission theyll do it, I remember on my p's driving dads falcon which is stock as a rock. And he got epa'd for the time I was driving. If they can they will. Oh and my car wasn't on ferntree gully rd like they said it was parked in undercover secure parking at work in the cbd
can you prove it was parked in the cbd at the time of EPA?
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
