Sorry to re-ask a question that has doubtless been asked before (Search turned up nothing, however) but:
If, for example I set the cam gears to +4 degrees inelt & -2 degrees exhaust does this mean the timing needs to go to 16 degrees BTDC on the crank.
Can anyone with these adjustable gears on a stock RB26 (+ pods + exhaust + 1 bar boost) confirm these number to be about right?
I had this all figured out once, but old age & infirmary makes me forget. :kiss:
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/
from memory my inlet is advanced maybe 6 and exhaust retarded about 4. gave a nice lumpy idle, and heaps more power everywhere. I don't think you need to do anything to correct the timing. you just adjust the cam timing at the gear and leave everything else alone. it's been nearly 2 years since mine were done though, so if somone else has a better memory than me, listen to them!
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/#findComment-2910263
yeah sorry, since you remove the cas to do it I assumed you will re-set it when re-fitted. but you still want the ign timing to be 20 base, so that doesn't change. unless someone can tell me I'm wrong! 2 years is a long time for my poor memory!
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/#findComment-2910907
Yeah you need to reset the timing after you change the ex cam position, even if you put the cas back in the exact same spot it will be wrong because you have shifted the cam. Set at 20 base.
Thanks Femno & Baron. Put the things in on the weekend. Adjusted the CAS so the timing light was indicating the same as the PFC handset.
Results? Well nothing much discernable from the data logger. Problem being that turbo motors are greatly influend by ambient air temps & I can't log these. Subjectively it felt much better through 4000rpm and seemed to spool up a little quicker. So I am happy with the results.
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/#findComment-2915894
ok, found the graph. I overstated a bit. it was 26kw gain. and absolutely nothing else touched except for the cam gears. the ebc settings, and power FC settings were left alone. at one point there was even more top end, but not as fat in the midrange. i preffered more in the mid range so I stayed with the result you see below.
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/#findComment-2915986
yeah it was a good result. that was 2 years ago, car is a bit different now and with about 20rwkw more. my idle was definately affected. but I love it. sounds much tougher now. :D poor mans cam change I tells ya.
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/#findComment-2916025
  • 10 months later...
Timing wont change as the inert part of the gera stays in the same position in relation to the crank.. only the outer advances or retards.
Beware too as i have used a few of the cheap ones lately and found them to be timed way out IE 0degrees is actually closer to 8 (cant remmember if it was adv or ret) so if you getting cheapies then check the cam timing first.
I first found it on AROSPEED Sr20 gears where they needed to be advanced about 9-10 just to get lost power back.....
https://www.sau.com.au/forums/topic/156588-rb26-cam-gears/#findComment-3570370
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
