Hi guys,
T88Turbo, did you get a Japanese DVD - did it work?
Chris, you wrote "if it says DVD video ont he face of the unit then it supports it." Where abouts on the head unit would this be written? Do you have any pics?
Thanks, Ben.
it will be written on the front on the DVD/nav unit. its locked to japan though so its useless unless you code the DVD correctly.
I'm also working on a PnP solution for those on htis side of the country.
tom,
great idea, poor execution. the later ones run CAN and pulling that board WILL SHUT THE CAR DOWN. tapping the wrong wire will kill something or a CAN module.
the TV tuner is simple cracking that module open is another matter.
Chris,
The screen board as you could see does not have a CAN connection so it will definitely not affect your car in any way.
The TV on the other hand has a CAN connection which I think is only used for diagnostics which can also be run from the Sat Nav unit. Disconnecting the TV will not shut the car down. After all you don't need a TV to run your engine. I wouldn't recommend shorting it out though.
Tom
Edited by TomR33
tom,
putting this in for the ones that 'think' they can do this. the later ones are CAN. I know about the CAN lines into the TV unit. those lines also loop through the NAV and toll card.
you and I know what we are looking at - most here probably do not.
Thanks Chris - do you have a picture of what I should be looking for. I am buying a V35 sedan, and it clearly isn't a deal breaker if it doesn't have DVD, but if it did it might be fun to get some Jap DVDs to muck around with.
Do you know if it is a common inclusion on 350GT8 sedans?
I has a japn DVD rom. I put it in my GPS unit to avoid the searching noise every time start car.
Frank350GT - do you mean a DVD rom like a burnt DVD? Does it play?
Sorry for misunderstanding.
What i get is an origional DVD disk of JAPAN map, 2003 version, issued by nissan and xnavi.
If i put it in the DVD-ROM in glove box, the screen will show the jap map. very interesting.
Unsure what you mean here. usually if the pop up screen is there then all of the above is there.
as for the GT8 versions - unsure. most of mine have been coupes.
I'm 90% through a plug and play interface for nav for these so given a bit more time and it will be done. that will take car of the nav.
as for english menus - look at the G35. I'm working on this as well. though I still have a bit more to do there.
all fun and games with these things.
I do. as I said I'm 90% through it now. once I get it fully sorted and tested you will be the first to know. only hting I'm unsure on are the later V35s with CAN driven units. going to try a M35 as well.
Nooooo, please don't say that by "later V35's" you mean the 2005 models.
I think you'll find he does, the 2005 models are different in many ways even though they look the same.
Dami it,
Chris, just think of all the new models that will eventually hit our shores. wouldn't it be great to have a plug in solution ready to go for when they get here. :(
I didnt rule it out. its the CAN stuff thats screws with things. don't worry I'm working on it. I'll need a '05 for a guinea pig as well. not for a few weeks yet. 04 back I have covered. this solution is for NAV ONLY! (I'm sorting the TV another way.)
Please don't forget our M35's please please please. Although you do have plenty of time as it failed emissions testing again!!!!!!!
Cheers
Muz
hey guys,
I went over to check out the system that JapLink have got running.. the guy has managed to pass sound and video through to the main unit.. he is using an external gps unit which he claims is off the bmws but it looked like it was some cheap taiwanese rip i think it was called devtona or something.. tried googling but couldnt come up with anything.. the guy is charging $1800 for this setup! He has also managed to pass through a hdtv tuner box to the main unit which he is charging $900 for..
I'm looking at maybe putting together a carpc with a similar setup to this I've had a quick play with roadrunner and it looks pretty robust.. as for the gps im going to have a play with mapmonkey which can apparently display the AUS Destinator maps..
Has anyone tried setting up tv tuners in their cars? I am looking at a few hd car tuners on ebay going for about $100.. I wonder how good the reception is especially while in motion.. any ideas?
Edited by karim
hey guys,
no offence here. the VDO units are well into the $1500 mark with maps I know of another cheaper item as well that is loosely $1k. the TV boxes are anywhere from 100-$600 depending on what you want or spec. so it very quickly gets to the $2k mark BEFORE you get someone to put it in place.
to me if you are capable of doing a CAR PC in it - go for it. however if you are the slightest bit unsure - don't try.
the ones I'm doing are setup the same way. audio goes through the main unit. TV is the same. the whole lot will be a LOT easier once I get the plug and play setup done.
would be interested in looking at pics of the car you just mentioned as I have access to a LOT of nav products so I dare say I could find specs on it..
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
