Hey Chris you should start a new thread on the differnt applications you have figure it out that can be used in the V35 such as the TV, SAT NAV, etc etc . This one is getting really confusing it all over the shop.
will do. I just need to get admin approval.
I would be interested in that. I would like to do something with the screen etc. in the car especially since my car is now giving me the fcuk off (F0) error code! I am just not sure what is available, how much it will cost and the amount of work is involved.
I need a mule for sydney. I'm going to make a run down shortly. car needs to be done in carlton.
for more details on location and price PM me. it takes a FULL day to do properly.
you have pm
Edited by nismo 400 R N1
Hi Ben
I have been talking to a Russian company recently who is working on a conversion from Jap to English for the car computer. They wiil be able to conver all the screens to english that do not relate to the GPS function. The GPS is a whole other subject and one they may be able to help with in due course. The general menu/screen language fix should be possible withi the next couple of months. This may help you get rid of the FO error code as you should be able to read what it is saying.
Cheers
Andy
Hi Andy, I would be keen to get the menus translated - I have been watching the thread to see how you go with it. The problem with my CD player is someting different - the mechanism in the CD player is buggered - it can't play, change or eject CDs. It is apparently a fairly common problem with the V35's which is a pain because of it's integrated design. As a result I am interested in the full iPod integrations being discussed here, though I don't want to make my interior rattly by pulling it apart and back together again. However, if there was a good enough solution I could go to the effort.
I have read that the CD players sometimes randomly come back to life after a month or two, so I have my fingers crossed!
That is a problem they have warned me about. They have said 1 in 5 DVD players need to be removed and cleaned to get them working.
Hi chris,I have a digital box in my ute and have just bought an 03 v35.Does this mean i could reinstall it in the skyline to get the tv working?Also be interested in the language conversion Andy.And last of all did anyone have any luck with the stickers to translate the buttons into english.Cheers.Matt.
pretty much correct. you will need a patch lead to get into the V35 TV box. also the TV you have needs to spit out NTSC for it all to work properly.
I have a source for the CORRECT buttons though they are NOT cheap.
hi chris, are you referring to the actual buttons (as in replace the original) or stickers that will go over the jap ones?
thanks.
$POA. I have base prices for certain items but I really wish to keep them private. if you want to know - ask me. to do the whole lot is in the early 4 figure mark. the buttons- $190.
  • 2 years later...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
