Hey ppl
Just wondering what some of the top track speeds have been achieved in an R32 GTSt are?
Sorry if this is a repost.
I have a GTST and am just wondering.
julz
Edited by R32 GTSt KID
https://www.sau.com.au/forums/topic/157714-top-speed-in-ur-r32-gtst/
  • Replies 75
Posted Images
R32 kid -
As public forum, I think you should edit post to say "on a race track"
Just dont think the mods and admin would like that, and esp the above post saying 180 on public road...not good.
Hey ppl
Just wondering what some of the top speeds that have been achieved in an R32 GTSt are?
julz
Depends... with or without VTEC yo?
11ty billion m/s
I think it would be safe to assume 180km/h.
I would like to suscribe to you're newsletter if possible thanks Paul :D
But one question - how did you measure it in billions?
what sort of flux capacitor did you use and who was it tuned by? :P
With the RB20DET and 220 rwkw, 225 kph on turn in to the kink before the chase at Bathurst. It probably sneaks up a bit from there in the short straight, but I was too busy to look.
:P cheers :D
i used an ultra sensitive lidar which only has increments/readings in .11ty of a billion
my flux capacitor was tuned by kawaii_hachi_roku performance just down the road from PHATR32's track in northern mars
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
