If you can get your hands on the Japan GT or the old JGTC DVD's. The ones I have covered 2 rounds each from a few years back, and you get heaps of extras like incar footage from several cars doing flying laps while racing with no commentary.
The R34 GTR's are insane! Sound awesome and look extremely violent to drive.
awsome great watch! .. great work! :(
Race cars do sound noisy. Whats that noise, sounds like a banging over bumps and sometimes up and downshifting, or when letting it off. kinda sounds like a loose tail shaft or input shaft.
Or could it be the Race 6speed box and drive train causing that clanking? only thing we could think of... seemed as though it was getting quieter as he drove a few more laps.
awesome vid.
Looks hairy down the straight over the bumps soon after he clicks 6th. :(
That thing is just insane christ when those two turbs hit - boom ! has he got a fight on his hands that really is a monster of a car, be great to no what hp / kw it puts out> that aint no ordinary gtr....or is it ? :rofl:
That footage is simply stunning. The explosion of power and noise is astonishing, and the RB26DETT sounds awesome. The acceleration is quite awe-inspiring...... Group A gave us some marvellous cars......
Edited by ajrichar
  • 3 weeks later...
would you be able to list the file names so i can search for them
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
