Hi Uras,
I'm following this tread with great interest. Hoping to have a chance to learn the software/tuning compare to HKS Fcon SZ or Is which require Selected HKS writers workshop only. I drive a GTT and planning to upgrade turbo & injectors soon.
Any chance of using the FCD/Speed cut function without doing dyno / road tune? Does it plug-in and has default setting for the fueling & timing like the PFC? Currently few workshop who install/sells EMU has somehow experienced burn coils or blown engine, so im am hoping you could shed some light on whats causing them whether it wrong parts install, wiring, setup programing? At least i have some knowledgeable answer if we do hit a wall during installation/tune.
  • Replies 765
Hi Uras,
Workshops who burn coils do not follow instructions unfortunately.
The EMU when first fitted does NOT alter any engine parameters until programmed so you can confidently fit it at home and drive to wherever needs to tune it without fear of engine damage.
sydney is ass for lots of things unfortunately, if i had a dollar for ever time some-one offerred me a tuning job (emanages/pfc) there i would be laughing.
There are some very good emanage tuners there though like Jim @ CRD.
what about somewhere where i wouldnt be paying through the ass? :P
does anyone know what jumper have to be changed to run it on a series 1.5 r33? it has the series 2 motor so i know i will have to change jumper 8 to 12v, but is there anything else that has to be changed? the main ones i need help with are:
10 (which is the second afm input). it is default set to gtr setting. the other setting is vtec out. do i leave it as gtr or set it to open?
17 (which is frequency output / vtm output). do leave it as karman output?
everything else i m fine with. i just want to get a second opinion on these before i plug it all in.
Thxs Uras, you probably rite about inexperienced tuners. Going to do more checking on the software & setup manual. Appreciate your assistance to guide us on EMU, this tread will get frequent visits for those looking for PFC alternative. Cheers!
Leave the rest of the jumpers in the STD positions, see manual for factory jumper settings.
hey
mad082 was installing one of these today and he set the jumpering for an s2 r33. The car started up and idled fine for a while, then was misfiring pretty bad and wouldnt turn back on. He took the emanage off and it still wouldnt start up.
He was saying theres no spark in any of the coils. Does it sound like the coils might of died and if so why would it kill them if he had the jumpering correct ?? the car is a r33 s1.5.
oh yeah he also told me to say he hadnt changed any of the important tuning type stuff, he was just playing with the rev limiter setting.. he claims :(
if anyones got any ideas let us know please
thanks :P
how do i get to the data sampling? i don't have that icon on my screen? all i have is a data logging, but no the one that shows the maps. it is just the one that graphs it.
you have the old software version
download this: http://www.trust-power.com/03electric/Ulti..._Vmanage103.exe
hey
oh yeah he also told me to say he hadnt changed any of the important tuning type stuff, he was just playing with the rev limiter setting.. he claims :P
thanks ;)
internal or external ignitor?
  • 3 weeks later...
i am having trouble getting the a/f meter working properly through the greddy. firstly i am not sure which wires i am supposed to hook up. we have an innovate lm1 o2 sensor kit, and it's output plug has three wires (red, white and 1 with no casing). the emanage has 2 wires (white and grey). now i found the greddy wiring diagram for it, but the innovate diagram doesn't say what colours the wires are. it just says what the 3 wires are, but doesn't say what colour each one is.
also i tried just touching the wires together and i did get a reading of sorts, but it was completely different to the reading on the handset. the handset was reading high 14's (was cruising) and the emanage reading started at 12 and then dropped to 8 and wouldn't move. do i have to change something in the innovate software?
also, what nvcs settings are people using? what rpm and load are people having it turn on?
You need to set the output signal in innovate logworks to get the readings to line up as no two widebands give out the same signal out of the box.
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
