im pretty sure the wiring mod from GTR to GTST is the same on all of them. only difference is you'll need some sort of resistor or something (sorry for being so vague) to convert the 5v feed for the igniter to 12v.
read through the pages and you'll come up with your answers.
  • Replies 765
Thanks guys,
not sure I'm up to installing it myself... have heard a few professional have had problems if they don't know what they are doing (or new to the e-manager).
does anyone know any tuners in Bris / Gold Coast that work with them?
i got my emanage blue tuned my pro torque, pete knows the emanage back to front and has tuned a fair few of them. give him a call on 0438 876 649 he is at springwood
Hi security. :P
Yes i have read all of this thread pretty much thats why i bought the emu.
I have set jumper 8 to 12V as instructed and installed the other crossover/ internal plugin for 34 gtt.
I just need a deffinate answer on the gtr harness compatibility into r34 gtt.
I have the universal harness already but would rather it was easily removable.
Thanks again. ;)
100% does not come clos to fitting. R34 GTT will not ever have a plug and play harness i have been informed. :nyaanyaa: maybe buy a field harness instead.
Wheres Trent gone ??
He must be busy
hasnt responded to any of my emails for ages
sorry yeah have not been in for weeks.... flat out with work day time and AH. my work email has a new filter so i figure that is why i havent recieved any of your emails. sorry.
cheers trent
damn it :whistling: .
Thanks for confirming that. i suppose the only option is the wire in harness.
going to be difficult to remove if i ever wanted to.
the way the wire-in is designed is that if you ever wanted to remove it you could take the emu wiring out and plug the previous wiring back into each other. the emu comes with some 'clip-lock' crimpy things. just pay attention to the way it goes on and it will be easy to reverse.
get someone to order you in one. i doubt many shops will keep it in stock.
taa mate hoping someone might know if anyone has stock...slide will have stock around about the 16th sept
anyone know where i can get a N4 plug n play harness....no ones got stock
TRUST japan was out of stock, soon all our back orders will be filled and we will have 100 on their merry way.
TRENT:
Ive got a 200sx with the ca18det , and having problems with ignition misfire , have tracked it down to 3 volt on the AFM but it dosent happends all the time , i have a Pressure Sensor from greddy and followed your guide but the car runs like crap with it :blink: whats wrong :)
And wich map trees do i need to remap , only did Temp map for the engine idle because ive tossed the a.c.c valce to hell... got a plenum from custom plenums here in australia instead... And also Injector map ... noticed that it hase a idle map indeed and accelerator map and so on... what does they do :D
And also do you know what lagtime it is on pink Nismo 555cc injector (topfeed) for the CA18DET , bought them from Greenline but havent got a reply for my answer in month , know i use stock 0,6ms on the nismo aswell...
Also is there better to use 300zx MAF or Pressure Sensor , im not going to get over 400 horsepower.... should i sell my pressure sensor and go with the maf ?!
Can´t go to you guys because i live in Sweden so a couple of guidlines or hints would be great... Have started a thread on EmanageForums but didn´t get my problem solved... when the engine stalls it help to clutch and rev and it dissapears... and it dosent happend every time... have tried new sparkplugs , coilpacks and so on... Buddy of mine hade the same problem so he bypassed the coils and it dissapeard , we did then the same on mine but fault still remains...
Link to emanagethread :
http://www.emanageforums.com/forums/showthread.php?t=901
Please someone help !
Hi all, Justa quick question what are the benifits of having the ignition harness? and the injector harness? what do they do?
I will be running aftermarket injectors nismo 480cc on my r34 gt-t. do i need the injector harness?
Thanks guys :laugh:
Thanks guys :)
ignition harness allows you to adjust the ignition (timing).
injector harness allows you to adjust the duty cycle of the injectors (fuel).
yes you will need the injector harness to take advantage of the bigger injectors.
and i'd recommend getting the ignition harness too. dont be stingy.
Trust have specific harnesses for most vehicle types. To avoid any damage when installing it is recommended to use the correct harrness for your vehicle. When using a harness there is no need for the optional injector or ignition harness.
I found that on nengun while invesigating pricing on additional harnesses. Now im really confused.
Anyone please clarify?
Hi me again, just thought id post what mods i have and are about to complete to give you guys an idea of where im heading.
My mods are
R34 GT-T
Hks front pipe and Hks dump into high flow cat and Trust PE 2.
Hks type S FMIC.
Hks Gtrs kit.
Tomei fuel pump.
Nismo panel air filter.
C's short shifter.
Greddy Profec 2 ebc.
Splitfire coil packs.
And these are soon to be installed.
Nismo 480cc injectors.
Nismo FPR.
Z32 airflow meter.
Emanage Ultimate + universal wiring harness. (jumper 8 set to 12v plus internal plug installed)
My goal is 250rwkw (streetable, daily, reliable power)
Ok hopefully that clears up why im asking questions about the injector harness and the emu in general.
Thanks guys.
what they mean by that is they have a harness you can buy with all the wires that you'll need already connected, so all you do is plug it in and off you go. they ONLY come with ALL the wires ready to go as its a single unit.
the separate harnesses are used if you're going to wire them in 1 by 1 or if the specific harness kits dont come to suit your car.
Hi security thanks for the response, my universal harness has 3 plugs at the ultimate end. ie theres no more room for any other plug into the unit. Surely this means that i have all the necissary wires to control the ignition and the injectors. if not where does it plug into?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
