  • Replies 765
Innovate LC-1 $200 bucks delivered from USA. Found on ebay. Wideband and narrowband output, replaces the factory O2 sensor and narrowband output goes into the stock ECU. Wideband output goes into the Emanage and gives realtime A/F ratio between 7:1 and 22:1 on your laptop. As said above, can be used to do a basic air/fuel ratio tune on the injector maps.
Also, as far a plugging the wideband output into the option port of the emanage, I just used a small terminal from a battery plug brought from Dick Smith. The only pin that needs to be connected is the far left side pin if using the option 1 port.
yeah the lc-1 is ok for starters but the lm-1 is the go.
it should use two to give more acurrate readings.
This might be a silly question, but is the use of the emanage units limited to Jap cars?
I.e, theoretically, could I use a blue emanage on a BMW 323?
BTW, I'm not crazy :P
depends on ignition signal some cars are not compatitble.... we tried XR6 turbo to no avail :D some euro bosch systems also dont work.
Aren't magnas jap?...
Is there a way of working out if its possible, or is it a trial and error type exercise?
I might give it a go, there's a gold emanage for sale cheap on NS atm, and if it doesn't work in the BMW, i'll use in the drift pig :P
Thanks guys.
Trent, i need your help mate.
i followed your instructions to remove the AFM but every time i put the data into the Airflor Output map and as soon as i do, the car either doesnt start, or if i do it while the car is running it will start to spew out black smoke and eventually stall.
what am i missing?
i did it VS. Throttle position AND AFM Voltage and i got the same thing.
do i have to unplug the AFM for it to work?
does the MAP sensor need to be plugged in? if so, what settings do i punch into the emanage?
It appears I have one of the earlier EMU's, board letter is © and serial is GSCII03111. Is this going to be a show stopper for my RB26 install? I assume all this means is I can't use my EMU to detect knock. [edit, see below post]
Using a plug and play GTR loom I connected this for the first time yesterday with neutral software setup and a stock engine. The car runs but there's a lot of fuel smoke on idle and driving at low speeds/power was very rough, felt like ignition was cutting in and out and it seemed to get worse if i opened the throttle more. Haven't made any modifications to maps & car runs perfectly on stock ECU. I haven't done much logging yet but the bit I did do showed 100% spikes of injector duty or cycle (can't recall which one, don't have it in front of me). Any ideas... i have set jumpers to factory defaults as below.
Jumper: State
1-6: Open
7 & 8: 1-2
9: Open
10: 1-2
11 & 12: Open
13 & 14: Open for knock sensors, 1-2 for temp sensors
15: 1-2
16: Open
17: 1-2
18: Open
19 & 20: 1-2
Note: There is a jumper setting typo in the installation manual. The overview table of jumper settings on page 6 says for Jumper 17, open is VTM and 1-2 is Karman output..... but then on page 8 under the explanation of jumper 17 it says "JP17 Frequency Output / VTM Output. This jumper will configure pin 21 channel in the Connector B (18 pin connector). Set to OPEN for Karman airflow meter output signal. Set to 1-2 for Honda with VTM signal."
The instructions that came with my plug and play loom support table on page 6 so i have gone with that one as correct. Can anyone confirm this?
Thanks
Wegs
Edited by wegs
Mohdparts.com have told me they don't think the GReddy e-manage Ultimate injector adapter #2 - #15901504 will work for RB26. Trent told me the same as he didn't use one on the driftcat RB26. So I will continue looking elsewhere for an answer to my above post.
They also said the software & not the board version determines the knock sensor abilities of the EMU. I will try hooking this up and see if i can get a reading.
Wegs
what am i missing?
yeah the map sensor needs to be plugged in and selected in the options menu.
check out the file i sent you and set the scales in the output map to the same. if you get stuck let me know and i will go through it tonight on my laptop and MSN with you..
i just tried it again with the map sensor selected, and with your output map as well. same thing. it just stalls.
your not using my data though are you? as rb26 and rb25 are totally differrent. If you are thats the problem.
email me your EMU file (with airflow datalog) now to [email protected] and i will set it up.
What about for RB25
I have over fueling issues at the moment and was hoping that adapter would solve it
is your water temp reading right? what correction do you need in the map to get the mixture right? and what serial number?
no i only copied the airflow output map.
im emailing it now mate.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
