hi, first time i'll be changing the oil in the new car (32gtr) and just wondering what these things like best? specially considering it's starting to get pretty cold here in canberra. also, are there any pointers about changing oil on these things or will it be as straight forward as my falcon? cheers guys.
ps, did search this but was surprised not to find anything.
https://www.sau.com.au/forums/topic/161928-best-oil-for-rb26/
personally I wouldn't use anything other than Motul Chrono 300V 10W40.
for some reason, my motor does not like it
the car had a ticking noise at the top of the engine on cold start when i used to use 300V 10W40.
then did a bit of reading, found out that full synthetic oil can drain from the head...thats why i switched back to 4100.
but my car is only a road car, with a very light tune on it.
cheers guys. advantages of the 10-60w? is it just better in the heat?
In theory yes, heat meaning full race conditions not just a 40degree day, but do you need to spend that much if you are not racing.
Most people agree you need a fully sensethic oil. The nissan manual refers to 15-35w oil. Oils have improved since the manual was made. The lower the first number "generally" means the quicker it lubricates the engine at start up (where most engine damage occurs in a daily driver). Lubrication = protection. Canberra gets real cold in winter, starting a car in sub 0 weather benefits from a lighter oil. For more details and debate on oils see the what oil should I use thread, lots of good reading.
5 litres $50 for my oil.
X 2 i got a r32 gtr, shredder667 u can get it from Autobarn in fyshwick if u get stuck give me a PM i live in Queanbeyan
X 3
Did all the oils for mine a couple of weeks ago...
motul 300v 10w40 for the engine
red line lighweight shockproof all round for gearbox/front and rear diffs
not enough redline High temp ATF for the transfer case so ended up getting some castrols in there at the moment.
bit costly but drives smoother than ever :)
jeff
I've lost two engines using motul 300v doing track days, after the last one i switched two Nulon 15w50 full syn and a dozen track days later still going fine ( over a period of five years )
which 300V and what else changed in that period of 5 years?
10w 40 and two engines, oilcooler on second, unless there's somthing inside this one i don't know about but it should be stock and been in place for 3 years.
The factory workshop manual recommends 7.5w 30 sg grade ( but thats for japans weather ), 4.2 liters without filter change and 4.6 with.
Edited by XKLABA
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
