hi, first time i'll be changing the oil in the new car (32gtr) and just wondering what these things like best? specially considering it's starting to get pretty cold here in canberra. also, are there any pointers about changing oil on these things or will it be as straight forward as my falcon? cheers guys.
ps, did search this but was surprised not to find anything.
https://www.sau.com.au/forums/topic/161928-best-oil-for-rb26/
personally I wouldn't use anything other than Motul Chrono 300V 10W40.
for some reason, my motor does not like it
the car had a ticking noise at the top of the engine on cold start when i used to use 300V 10W40.
then did a bit of reading, found out that full synthetic oil can drain from the head...thats why i switched back to 4100.
but my car is only a road car, with a very light tune on it.
cheers guys. advantages of the 10-60w? is it just better in the heat?
In theory yes, heat meaning full race conditions not just a 40degree day, but do you need to spend that much if you are not racing.
Most people agree you need a fully sensethic oil. The nissan manual refers to 15-35w oil. Oils have improved since the manual was made. The lower the first number "generally" means the quicker it lubricates the engine at start up (where most engine damage occurs in a daily driver). Lubrication = protection. Canberra gets real cold in winter, starting a car in sub 0 weather benefits from a lighter oil. For more details and debate on oils see the what oil should I use thread, lots of good reading.
5 litres $50 for my oil.
X 2 i got a r32 gtr, shredder667 u can get it from Autobarn in fyshwick if u get stuck give me a PM i live in Queanbeyan
X 3
Did all the oils for mine a couple of weeks ago...
motul 300v 10w40 for the engine
red line lighweight shockproof all round for gearbox/front and rear diffs
not enough redline High temp ATF for the transfer case so ended up getting some castrols in there at the moment.
bit costly but drives smoother than ever :)
jeff
I've lost two engines using motul 300v doing track days, after the last one i switched two Nulon 15w50 full syn and a dozen track days later still going fine ( over a period of five years )
which 300V and what else changed in that period of 5 years?
10w 40 and two engines, oilcooler on second, unless there's somthing inside this one i don't know about but it should be stock and been in place for 3 years.
The factory workshop manual recommends 7.5w 30 sg grade ( but thats for japans weather ), 4.2 liters without filter change and 4.6 with.
Edited by XKLABA
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
