  • Replies 73
Yeh, that's not cool... the 96 model was OK looking, the bug eye sucked then they fixed it in 2002(ish) and i was happy with how it looked, then came the latest rex which is nice except im not a fan of front lights/grille, and now they've totalled it and brought this out... why don't they poll outside the company before designing these things!!??!
looks more like someone has welded the front from a last generation camry onto their astra :sick:
dont mind the rear view, but bonnet scoop is way too big.
Pics still look farily 'fake' to me however i have seen spy shots of the new wrx in motor mag a while back and it looked strangely similar to this
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
