I want to get a custom RB25DET manifold ( tuned length ) but people have said that it is not worth while if it is going to take the standard turbo position ( HKS GT2835 pros kit ). It wont be able to have decent runners or collector design? So I was thinking of extrude honnig the factory at UAS. Any one made any noticable power gains???? Also anyone here cracked over 300rwkw with HKS GT2835 .87 a/r cams etc? Ive been reading that the WG has trouble holding boost..How bot weliding shut the interanl and using a external WG???
https://www.sau.com.au/forums/topic/163142-extrude-hone/
I dont think anyone has done much testing back to back. ie, before/after exclusive.
Other changes were also made at the time so its hard to attribute a gain (if any) to one specific thing when 3-4 parts are changed.
IMO, its a waste to close the external gate on an int gated turbo.
You may aswell just begin with an externally gated turbo/manifold if thats the case.
Hyrid styles like that im not a fan of. It has been proven to work, but also if not done right can cause problems
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3027560
There is one bloke. I forget his alias. Orange R33 in his Sig.
I believe he had UAS power port/extrude hone his std exh. manifold but he is/was oversea's so he was unable to test.
He's running a gt2835 and currently making up around 280rwkw.
I'm very keen on seeing his results. Maybe UAS could shed some light on if the extrude honed std exh. manifold allows it to push considerably more than the 300rwkw brick wall the std exh. manifold usually see's.
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3027656
only problem with extrude honeing is that the bumps that would usually be taken out with a die grinder are still left in. unless they do that also!!
it opens the manifild up yes!
but doesnt get rid of bumps.
if you'd look in a gtr manifold for example there are many large bumps in there!
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3027713
I did a back to back on an SR20 manifold.
Overall I wasn't blown away with the results. There was definetly gains though.
The problem aparently with my manifold to begin with was the runners where all very un-even. So rather then focusing on increasing
the overall flow he spent the time making the flow even.
Gave me piece of mind that each cyclinder was getting the same amount of air but not massive gains to talk of.
As also mentioned there were still a few bumps left. The finish wasn't as mirror like as i expected.
Again though this could be because he was trying to make them even.
I've done a much better finish my self by hand but obviously I can't get to the area's in the manifold he can with the dinosaur poo.
Its definetly worth doing but I think only at the top end of the scale.
I would also hand port anything this time before i sent it of to be honed.
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3028025
Butters,
Was the manifold pushed to its limit prior and after?
Yer pretty much. Car was making 400rwhp. It would lean over quite badly from 6500 rpm to redline.
I gained very little more top end hp at the same boost but the power drop of was much less dramatic, it made around 20 - 30 rwhp MORE at 7500 rpm.
Was trying to avoid buying a greddy plenum, as I have seen them loose a heap of power from 3500 - 5000 rpm due to the short runners.
Got me the result i want but I don't think its the ultimate solution for out right power.
Note this is SR20 info, so results may be quite different for an RB.
Edited by Butters
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3029007
dont be fooled by the short runners theory.
i have seen short runner plenums make less lag, more torque and power creating some of the most responsive packages considering the other boltons used.
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3032798
why are you concerned about 3500-5000rpm if your chasing outright power.
i mean , i understand its probably a street car and driveability is the main advantage ,therefore low/mid range is important, but if you want outright power at 7500 revs , then go for the greddy unit , with the short larger i/d runners.
anyway i had my old vl turbo plenum/runners power ported , and made a very noticeable difference over the dead stock vlt setup.
now with the newest setup on my car i have an aftermarket plenum , and that has also been thru the hands of andy sanders at specialised power porting.
im a firm believer that it works.
my compressor cover is also done.
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3033388
sly33 is the bloke who has just had his std exhaust manifold extrude honed/power ported. ~34cfm increase per pot.
Legend also had some data on flow rates.
standard manifold .........hks cast ...............hks cast flow honed
1 159.7.........................170.7............................194.8
2 162.4.........................166.6............................203.4
3 160.7.........................178.7............................198.7
4 150.1.........................183.6............................200.3
5 149.9.........................182.2............................207.8
6 173.3.........................184.7............................202.8
http://www.skylinesaustralia.com/forums/in...t&p=2682373
also this link from UAS with some more data.
http://www.skylinesaustralia.com/forums/in...c=82555&hl=
Obviously flow isn't everything as in the real world merge has a large influence on overall performance of the manifold.
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3033720
Devils_Advocate21 - refer to spoolup and 2bnvs dyno results, these are both 25/30's but you get the idea.
dontfeelcold - they sure are
but were are not here to talk about my plenums, mod's get the sh1ts and with good reason, i am just sharing what i have learnt from my experience.
as Cubes says, it is not all about flow or how evenly it flows on a bench because real world stories for turbocharged engines are a different ball game. there are plenums out there that flow very very evenly on the flow bench, wont name them but the 2jz ones made in the US are big $$$'s (read: rip off), but require adjustment to fuel distribution to the rear cylinders 5 & 6. then again you look at the flow results of several rb30 plenums that retain all or part of the standard runners which show variances from 3-8% and have absolutely no problem with distributing air which provides some of the best consistency between cylinders without adjustment of individual injector/s - poor old microtechs dont have that function YET :sick:
PS forgot to mention all those results are acheived with a 80mm billet throttle body....kind of makes you think what people say about big throttle bodies and short rrunners huh..........:D:):):):)
Edited by ISL33P
https://www.sau.com.au/forums/topic/163142-extrude-hone/#findComment-3033832
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
