mikyel .. you cut off the plastic melted bits and glue it back on after your finished.. I painted over mine tho ... Looks shit..
RGR you slide ur fingers to the back of the gauges .. close to the front window pull toward you and pop it out .. pull out the air con vents remove the screws and then remove all the interior parts and spray
I went and bought myself some black paint to fix up the window switch surrounds and we'll see how that goes..
Can anyone just give me a quick idea how to get them out? Do they just pop out?
Hey Dan,
Top job mate :closedeyes:
got a question, where did you get the nissan paint from & were you able to get it in spray can containers?
Where did you buy the Desert Rose metallic from too please.
I've been looking to do this for a long time, you've just given me the motivation :)
Cheers
For those that know how bad the factory interior paint is on the R34's (seems to dissolve in the Aussie heat)
I've found a low-semi gloss alternative that seems pretty good, Powerplus PJ9184 "SNB 150 Desert Rose Metallic"
Just soak/scrub the original paint off with metho, takes no time at all, prime and hit with this stuff and in comes out looking pretty swish again.
Looks like I'll be doing this too when my rear bar goes on.
Whilst the car is in the shop, I'll pull the bits out, clean em up, and get them sprayed the same colour as the car, then layer on some clear coat.
Top work Dan.
How hard is it to pull the window controls apart?
sam ( im pretty sure thats ur name, from memory I got told off for spelling ur user name wrong :closedeyes:) neways to remove the panels u have to remove the left hand passenger side door cover and take out screws under neath it .. a fair few screws..
Drivers side rear pops up disconnect winders etc and you pull back and slides out .. wish the passenger side did that .. i ended up finding out after dark and doing it in the night .. which was not kewl!
Hope that helps ..
Just a tip for people thinking of respraying over the crap paint .. I did it and under heat/wet conditions the paint bubbles .. so sand it back ppl
NPS! Hell yes! and what makes it every shitter is that you dont have to remove just two screws its bolted in there harder than metal to a tank .. serious about 10 screws in the whole thing ..
neways enjoY!
Nsm34
How the hell did you mask up the red and blue temp adjuster? That's great work.
I've decided I will definently be doing this to my car whilst my rear bar and skirts get sprayed. I'm going to do all the crappy painted bits in the same colour as the outside of the car.
Would you be able to take a picture of the whole centre console including the gear stick surround?
thanks
Nsm34
thanks
you dont mask anything up. you need to take of the face on the ac unit. I then used a soldering iron and melted the lugs holding them in the back. When i was finished just put them back into place and melted the plastic back over again. too easy. I will try to get that pic as soon as i can
  • 1 month later...
  • 1 month later...
Tamiya (model) spray paint I tells ya....no priming necessary, great range of colours and they are meant for plastic
http://www.skylinesaustralia.com/forums/in...st&id=91076
http://www.skylinesaustralia.com/forums/in...st&id=91075
Is Tamiya paint safe for UV Light (from the sun), and safe for high temps (cars get up to 70-80 degrees in summer)?
I picked up a can of semi-gloss black, but want to know its a good long-term paint before i use it!
  • 9 months later...
Where can we get it from???
  • 4 weeks later...
Hmm can't figure out how to remove the dash/units. I've removed the ash tray, unscrewed the screw and popped out the plastic surround around the gear shifter. (tiptronic). However, I can't seem to pull the plastic forward, as the other plastic for the P, R, N, D, 3, 2 seems to be in the way. I have tried lifting this up, but it seems that only the left side comes up and I can't remove it.
Please help!
Nick
Supercheap stock all the Powerplus spray packs and will have desert rose metallic in stock in all stores...the factory silver Nissan colour was from Autobarn, they make to order.
You need to give it a bit of force to slip it over the PRND32 section, go from the back forward though, there is a little screw driver lug on the right hand side (just left of the rear of handbrake boot) to help you pop the clips.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
