Do you know who does that or where can do I that here in Perth ?
Can't help you there, but everyone in the thread has done it themselves, i'm certainly no painter but it was really quite easy to get a nice finish, have a stab at it yourself, you'll be surprised at how easy it really is.
Haha if you're saying that it's really easy,maybe I should try to do it my own ? Where can I buy the paint or the finish ?
I don't the shiny glossy look,just like the one on this thread is fine (Goldish silver)
Thanks !
Thanks !
If you flick back through the pages of the thread you'll find all the info you need,
The paint can be had from Super cheap/repco etc...
If you don't want gloss, just don't put a clear coat on at the end, That color i used was the same as a few others, its Tungsten and comes in a pressure pack spray can from Super cheap auto
What should I look for at Supercheap ? I mean what is it called or what brand ?
I don't remember the name, it's probably in this thread somewhere, go back a few pages and have a look, other than that there are only 2 or 3 different paints in a can in supercheap, it's really up to you what you use, its not hard to find.
they are real easy mate, i just did mine. For console, start at gear surround, take the screw out behind the ash tray and then pull the gear surround up gently. and then you can work your way up from there.
heres some pics from mine, i used 3M Vinyl Paint - Satin Black. No gloss or primer, IMO looks too cheap when gloss is applied.
for the driver side it just pops up, get a flat head screw driver under it and gently pull it up. for the passenger side, you have to take off the whole door card. heres a link on how to do that:
R34 Door Card Removal
cheers mate. i dont understand why nissan didnt make the plastic black to start with. but it deff worth the time and effort. i hated looking at the old paint, every time you touch it, it would leave finger prints thats how soft it was.
  • 3 months later...
Yeah Delta is right, take the sticky shit off...takes minutes with metho. The final product is only as good as the surface preparation
Also I didn't use clear coat over the Power Plus "Desert Rose" I wanted it more matt/semigloss like factory..so avoided any gloss.
Another tip, when priming use the primer sparingly as *ANY* pooling of primer will eat the plastic trim as it has massive amounts of Toluene as solvent, you'll get what looks like crazing and cracking in the surface.
Take as much time as you can, don't rush, be patient and everything will go great.
i got some crazy cracking in mine ganna hit it with s/paper and paint again should fix it?
my try :unsure:DSC_0718.jpg?t=1314084905 now
167672_193815610644338_100000477008080_713245_2172576_n.jpg?t=1307869458before :yucky:
im lookn for a A/C display cover they painted over the screen and its F!@#ed also they painted over the hot cold so i unsolded the tabs pulled em out little clean and solded them back in :blush:
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
