  • Replies 237
Posted Images
hahah i kept thinking the same thing Troy. Watching it i'm going, wow he's moving... then i timed him and thought shit, i'm (hopefully) going to be going faster haha...
It is the Nation's premier power track afterall . . . . Hehe, I don't know if I'd bother turning up even if I HAD money or a gearbox in My car ! ! Neeeed POWWWWWWWAAAAAAHHHHH ! !
hmmm, manifold pressure compensating Fuel regs on ebay for $120, looks interesting . . . . . ;)
Strange. I was looking at that lap and thinking man he is flying. And braked way later then me over the back. yeh he was 4 secodns slower. Hmm, maybe i will be lucky to wipe off half a second :)
I swear I would have made up 2 seconds of my 3.5 second improvement there last time just by getting some more balls on the back straight... hairy stuff though! Great fun :D
Sandown is still great without a lot of power, and the time can be made up... a little ;)
Hardman: Nigel was only 1.5 seconds quicker than me in the 450rwkw Supra last time we went. Not sure if he was running full power or not, but it sure looked quick on the straights!
hahaha i don't expect to be anywhere near snowy or jack, first time out and lack of skill, you know.... Should be fun tho, i'm getting pumped....
Ferni,
You and I are line ball on nearly every track. Look for a low 23 and you know you would have had a good day.
Best of luck.
Andrew
Ferni,
Best of luck.
Andrew
I noticed the same thing... at least we have each other to chace, screw these guys doing sub 20's around sandown...
Got the car ready on sunday, can't wait to get out there, little bit nervous even though I'm doing driver training lol.
Yeah you'll be nervous just before you go out, once you're out there it will all just come to you, and you'll start having fun :closedeyes:
Yeah you'll be nervous just before you go out, once you're out there it will all just come to you, and you'll start having fun :P
Well done Ferni, a 1.22 is really moving.
http://www.racetime.com.au/?event=s0701&am...mp;view=fastest
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
