A few weeks ago I had my R33 Skyline Diff Shimmed By Ray at RE Customs.
Prior to this my diff would always single spin, so I was looking for a solution to this.
My original thought was to buy either a 1.5 Caz diff or I was also looking into the Nismo 2way.. Both of the mentioned diffs were approx $1500 - $2500 installed so some big dollars.
After speaking to Ray about some possible options he suggested that I could add “shims” to my original single wheeling Nissan Diff to tighten it back up and all for a very affordable price. (Under $400)
The diff can be tightened up using various shims in the diff as per the list bellow:
0.80mm
0.85mm
0.90mm
1.01mm
1.05mm
1.10mm
1.20mm
1.30mm
1.40mm
1.49mm
Based on the selected shim you get a various desired tightness to the diff.
I asked ray to make my diff tight so it was something similar to a 1.5 – 2way Diff.
This was achieved by placing 2 shims additional to the original ones (1 on each side) 1.10mm thick to the diff.
This in turn has come close to locking my diff.
All I can say is its fantastic!!! This is also a very cheap option to fixing a single spinning Diff, and I highly recommend it to those who are sick of a single spinning diff and want a cheap replacement and fix.
I will also add that I am not one for doing things cheap but this does not appear to have any bad affects and is still using the original Nissan gear.
I took the car for a drive on the weekend and through some tight corners
Felt like it was on train tracks. The whole car now feels extremely stable so it has certainly been a viable performance upgrade.
If you’re interested in having this done to your car, speak to Ray at Re Customs and he’ll be able to give you a price and book you in if interested.
Re Customs - 9548 3414
https://www.sau.com.au/forums/topic/164346-fixing-your-single-spinning-diff/
i wonder how it would work on the vspec diff
as i can lock my diff on demand via a switch
so it could be a tight locker on demand
the problem i found with my one is that its a weak lock when it does
hmmm thinking to do...
shims arent a good way to tighten a diff :P
speak to a good reputable diff specialist n he should refuse todo it
i heard this, looked into it, asked for it to be done almost got sworn at... said a good set up tightened lsd shouldnt need to get shimmed ...
so perhaps look into doin a job properly :O
or ...
just weld it up and be done with it ... chirpy chirpy chirpy
From what I've read it lasts about 2 weeks....
shims arent a good way to tighten a diff :D
Really?
Racepace did mine years and years ago now. Before i pulled my car off for the RB26 motor conversion.
The diff did approx 12,000km's (9-10 months) which included lots of burnouts @ the drags as i was racing every 2nd or 3rd week :)
Lots of dyno work, street duties any anything else you car to think of.
Certainly worked ok if you ask me :cheers:
Really?
We dont just shim it, Ash.....:D
We re-machine it, add more clutch plates (most important) and then reshim... they then work really well and last.....
cheers
Ben
We dont just shim it, Ash.....:cheers:
cheers
Ben
Well, there you go.
This is why i pay you a great % of my pay each year :D
cheers
Ben
Is this similar to what you do to the transfer case in the GTR's? I hear from Jack that the re-shimming you did on his, did wonders for his handling on track.
Cheers.
Nick
We dont just shim it, Ash.....:)
cheers
Ben
Ben, any idea on what sort of $ are involved in this? I hate my single spinner! PM if you'd prefer.
BTW - Car is 100% after your work. Top job :)
cheers
Ben
hey ben
would it work the same for the vspec diff?
i have a switch to hard run the vspec pump so i can lock it on demand.
would shimming and changing the clutch in it make it really tight but only when the pump runs?
if so... can you quote a price? (or via pm)
I shimmed my stock VLSD diff which worked well for getting the power down on corner exit BUT in a straight line in first gear the left wheel would always single leg it, second gear would have a slight squeel from usually the left wheel and when the diff was cold second gear would spin up a single wheel as first always would.
I eventually got sick of the lack of traction in first gear and picked up a well priced R32 GTST diff that runs a GTR/GTS4 mech center with nismo 5 bolt axles.
It handles 100% better than the shimmed diff, much much more predicatable. It gets the power down much better/smoother out of corners and no more single spinning through first.
At least now I have an incentive to throw on a set of good tyres. Last time I threw on a set of good toyo's the left rear tyre wore so so much quicker than the right. :)
Shimming the VLSD is good for drift; pretty much for nothing else unless you preload it to the point of the spider gears completely binding. May as well weld it. :)
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
