A few weeks ago I had my R33 Skyline Diff Shimmed By Ray at RE Customs.
Prior to this my diff would always single spin, so I was looking for a solution to this.
My original thought was to buy either a 1.5 Caz diff or I was also looking into the Nismo 2way.. Both of the mentioned diffs were approx $1500 - $2500 installed so some big dollars.
After speaking to Ray about some possible options he suggested that I could add “shims” to my original single wheeling Nissan Diff to tighten it back up and all for a very affordable price. (Under $400)
The diff can be tightened up using various shims in the diff as per the list bellow:
0.80mm
0.85mm
0.90mm
1.01mm
1.05mm
1.10mm
1.20mm
1.30mm
1.40mm
1.49mm
Based on the selected shim you get a various desired tightness to the diff.
I asked ray to make my diff tight so it was something similar to a 1.5 – 2way Diff.
This was achieved by placing 2 shims additional to the original ones (1 on each side) 1.10mm thick to the diff.
This in turn has come close to locking my diff.
All I can say is its fantastic!!! This is also a very cheap option to fixing a single spinning Diff, and I highly recommend it to those who are sick of a single spinning diff and want a cheap replacement and fix.
I will also add that I am not one for doing things cheap but this does not appear to have any bad affects and is still using the original Nissan gear.
I took the car for a drive on the weekend and through some tight corners
Felt like it was on train tracks. The whole car now feels extremely stable so it has certainly been a viable performance upgrade.
If you’re interested in having this done to your car, speak to Ray at Re Customs and he’ll be able to give you a price and book you in if interested.
Re Customs - 9548 3414
https://www.sau.com.au/forums/topic/164346-fixing-your-single-spinning-diff/
i wonder how it would work on the vspec diff
as i can lock my diff on demand via a switch
so it could be a tight locker on demand
the problem i found with my one is that its a weak lock when it does
hmmm thinking to do...
shims arent a good way to tighten a diff :P
speak to a good reputable diff specialist n he should refuse todo it
i heard this, looked into it, asked for it to be done almost got sworn at... said a good set up tightened lsd shouldnt need to get shimmed ...
so perhaps look into doin a job properly :O
or ...
just weld it up and be done with it ... chirpy chirpy chirpy
From what I've read it lasts about 2 weeks....
shims arent a good way to tighten a diff :D
Really?
Racepace did mine years and years ago now. Before i pulled my car off for the RB26 motor conversion.
The diff did approx 12,000km's (9-10 months) which included lots of burnouts @ the drags as i was racing every 2nd or 3rd week :)
Lots of dyno work, street duties any anything else you car to think of.
Certainly worked ok if you ask me :cheers:
Really?
We dont just shim it, Ash.....:D
We re-machine it, add more clutch plates (most important) and then reshim... they then work really well and last.....
cheers
Ben
We dont just shim it, Ash.....:cheers:
cheers
Ben
Well, there you go.
This is why i pay you a great % of my pay each year :D
cheers
Ben
Is this similar to what you do to the transfer case in the GTR's? I hear from Jack that the re-shimming you did on his, did wonders for his handling on track.
Cheers.
Nick
We dont just shim it, Ash.....:)
cheers
Ben
Ben, any idea on what sort of $ are involved in this? I hate my single spinner! PM if you'd prefer.
BTW - Car is 100% after your work. Top job :)
cheers
Ben
hey ben
would it work the same for the vspec diff?
i have a switch to hard run the vspec pump so i can lock it on demand.
would shimming and changing the clutch in it make it really tight but only when the pump runs?
if so... can you quote a price? (or via pm)
I shimmed my stock VLSD diff which worked well for getting the power down on corner exit BUT in a straight line in first gear the left wheel would always single leg it, second gear would have a slight squeel from usually the left wheel and when the diff was cold second gear would spin up a single wheel as first always would.
I eventually got sick of the lack of traction in first gear and picked up a well priced R32 GTST diff that runs a GTR/GTS4 mech center with nismo 5 bolt axles.
It handles 100% better than the shimmed diff, much much more predicatable. It gets the power down much better/smoother out of corners and no more single spinning through first.
At least now I have an incentive to throw on a set of good tyres. Last time I threw on a set of good toyo's the left rear tyre wore so so much quicker than the right. :)
Shimming the VLSD is good for drift; pretty much for nothing else unless you preload it to the point of the spider gears completely binding. May as well weld it. :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
