  • Replies 45
1) SARDs are "generally" OK being a drop in injector that re-uses the old plugs
2) Camshafts? Might as well get the Tomei Poncam + Gear package if you got $5k to play with
3) Nismo / Tomei fuel pump will kick Bosch ass anyday
4) Nismo FPR (straight bolt on to the factory fuel rail)
Sards are not direct fit from what i saw. I watched them being installed onto a GTR two weeks ago :)
Was a bit of farting around to get the connector to fit, least they are not as bad as years ago... if you count that as a good thing
Cams for 300rwkw you wont need i dont think cost vs gain the cam gears come out clear winners for a couple hundred.
Dont see how one fuel pump is better than another, especially when price comes into it
I also doubt you'll need an FPR. Stock ones are fine.
Hanyou, send a pm to ferni, find out his setup as he has around 300rwkw on stock AFM/injectors.
Cheers
Cheers
So the plugs need to be changed / adapted with the SARDs?
I'd go for the camshafts - 300rwkw + high flowed turbos will be more than enough to make use of the cams (I'm only talking about Poncams here 260 degree 9.15mm lift).
Fuel pump; Tomei and Nismo take 20minutes to install... Bosch pumps take more because 1) there is no bracket; 2) you have to locate a good place for fuel pickup that will also reach the bottom 3) you need to do new wiring (possibly even the constant voltage trick). For the extra $200 I would get a pump that is completely drop in with nothing to worry about.
FPR is not required; agreed. Nonetheless - not a bad thing to have if you want to push out that little bit extra or set a base pressure to go by - I know of a few tuners who do this.
I'd be looking at a catch can system as well - quite a few GTRs with 300rwkw start to experience oil problems (especially those that see a lot of track time).
Yeah from what i saw :huh:
Needed some love, wasnt a direct fit, and, even with the mod... i wouldnt be confident of them not presenting issues further in time
ive decided cam gears will be enough, i've pm'd ferni about his setup as well. however id be assuming that the injectors/fuel pump would be running right to their limit?.
another question: do injectors need to be fitted same time with engine management?.
back onto the fuel pump topic. the only reason i was gna opt for the nismo/tomei pump was due to there is no sock thats attatched to the bosch?. ive had a 040 in my r33 gtst before didnt have any problems. i guess it just comes down to who installs it?
Get the engine management and the injectors put in at the same time and save of installation/tuning costs unless you install the ECU yourself (I did with my PFC) and run on the base map for a short while.
f**k pfc get a wolf v500 $1795.00
Real helpful
things i think you need.
nismo pump
sard 700cc injectors (they are pretty much a direct fit on RB26, perhaps you will need new o-rings, but i have seen people re-use them).
tomei poncams 260/9.15mm (get the set with pulleys, it's cheap)
Apexi Power FC
and a good boost controller if you don't have one already. easy as pie. and the nismo pump and power FC you can install yourself to save a couple of bucks.
AFM.s You will need the RB25 or Z32 Type...Plus adaptors....
Or if you have the money...Nismo type...same size as yours...fit on and tune
Sorry, but you are wrong. Unless hanyou's AFM's are already on the way out there is no need to change them.
offnsv: have you got a part number for those injectors? thanks
ill stick with the nismo pump option then since i can do it myself lol.
can someone explain the difference between poncams and cams? or are they the same thing?..
if i could save money on just using cam gears to hit my power level it would be better for me as i could get some rims.. LOL
poncams=cams. it's just tomei's name for their bolt in camshaft range.
i'm not sure how well these turbos perform so it's hard to say, but it certainly is possible to get 300rwkw without cams as long as you have the right turbos and run enough boost through them.
personally I would buy the cams and gears together from tomei. the set is quite cheap for what you get.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
