No damage to the heads its perfect. thank god!
Bore is fine in all 6
Oil pumps fine, so just need a crank and bearings and get the number 1 rod checked over.
Dirt Do you know if mark would have any R33 rb26 cranks he would sell?
Cameron
Number 1 has Hit the Head, We pushed on each piston and when we got to number one it moved down a mm or 2 :-(
So we will be pulling the res of the motor out tomorrow to strip it down and see what in the world went wrong, But its sounds like the little end thats kuput :)
How has the post-mortem gone? ie I would want to know exactly what caused the failure since there had been no contact between piston : head.
If the bearing is only gone for #1 I'd probably concentrate there first.
Oil pressure may have been fine, but is there any chance of a blockage in that journal?
Alternatively, maybe have a close inspection of the piston, rings, lands etc and look for evidence of knock. I'd think that detonation/knock serious and prolonged enough to cause bearing damage would have seen similar probs throughout and not confined to #1.
Well,
We spoke to Liddles Head Shop yesterday regarding this, AS he's who I turned to to check the cam shafts over. And he seemed to think that the main bearing would of let go due to the timing belt becomming so tight and putting too much force on the top bearing surface as the bottom surface on the number 1 main bearing is pretty much fine all the damage is mainly to the top side.
Main bearing 1 and the big end bearing on number 1 are the only bearings that are rooted.
We did inspect the pistons and rings and they all look perfect the rings look like they were running in nicely! We only going as far through the tune doing the base fuel tune/fuel pressure adjustment and 2 first full runs to 6500rpm held a nice 11 - 11.5 Ignition timing hadn't really been touched and there was no sign of detination.
Tomorrow we are goign to be re-checking the tollerances etc to make sure all that was spot on but we double and tripple checked it before it all went together.
The Oil journal is all clear no blockagepouded some oil down there and flowed through without any problems.
Cheers
Cameron
ive thrown RB30 blocks and cranks out...lol
got another whole engine given to me the other day because i wanted the oil pump housing off it.
dont go RB30...only wankers do that. :(
lol :D
My crank cost me $100 because I couldn't be bothered taking the engine home to pull it apart just so I could take the crank back to be ground.. so I just paid the guy to take it out for me seeing as the crank was technically already where it needed to be :rofl:
P.S. 3L torque ftw!
P.P.S. fair enough cam, I know what you've put into this engine so it'd be nice to see it all the way through! good luck bro!
Guys I have a fairly similar noise in my RB25DET and ive been scratching my head to figure out what it is. Heres the story
The motor itself hadnt been run for nearly 2 years. It was off the road for a build im doing to my 180sx. In this time I had the head off the motor, poncams professionally installed in said head and I bolted it back together with a new genuine gasket and ARP head studs.
A workshop got the car running and noise very similar to Camerons appeared. The workshop assured me they primed the car off the starter motor first to build oil pressure.
I havent checked that much myself so far, just a simple compression check which all came up fine (shouldnt be bent valves etc)
The wierd thing is, if I run the car for a while and take it up n down the block for example then the noise goes away. It only seems to be audible for the first 5 or so minutes the car is running.
What would this indicate? From my knowledge you will always be able to hear a bearing failure in a motor correct? Once they start they will not go away?
Thanks man. Should have included this in the original post but oh well..
The bottom end was left completely standard the whole time. It is an 80,000km bottom end and the noise wasnt occuring 2 years ago when I heard it running before purchasing the halfcut. When I had the head off the bores were spotless as well.
EDIT: I did turn the bottom end over by hand maybe a total of 30-40 times whilst the head was off. Would this have caused any damage to the bearings do you think? I had drained the oil but I thought there would still be residual left overs to keep things lubricated. It would have been turned over after just over a year of not moving.
Edited by rinmak
Well just got the number 1 rod back from Bryants Engineering in Sumner Park from being resized, they had to take 2½ thou or 0.063mm off it. I am hopefully picking up a R33 GTR crank this weekend. So the plan is to have it back together and in the car running before March :huh:
Well I need some Advice from all the knowledgeable people on SAU, I have no idea what would cause the following which I found today when I had a chance to finish pulling the block apart:
Oil pump:
Thrust bearing:
Another Issue I can see if with the clutch, Is there smaller throwout bearings for the GTR box? as I can see its not wearing in the same position as it previously was.
Edited by murrayis
Hey
get a impact driver and remove the srews holding the backing plate on the oil pump.
then have a look in there to see if the pumps shagged?
i would be getting a new pump personally regardless due to the chance of it being the cause of this, and also
the chance of it having metal filings in it.
Quick Update - Had some time today to start assembling the block, Spent 2½ hours this morning cleaning the block with a toothbrush and 4 ltrs of part cleaner. Installed the new ACL bearings lubbed them up nicely installed the crank and torqued the cradle down nicely.... moves so smoothly compared to the other one you needed a spanner to turn the crank.
Also cleaned up the pistons and installed and torqued them down to spec.
Hopefully tomorrow I will get time to install the pumps and sump then its just a matter of bolting the head back on and back to the dyno we go. I'll post some pics up tomorrow afternoon after I'm done with it.
Eye of the tiger, most people would have just given up and moved on. :)
Hey what did you find with the oiil pump? was it caused by the thrust bearing allowing the crank to move forward? If it was i would just double check the end float on the crank (thurst bearing clearance) so it doesn't happen again. Good Luck you Deserve a good motor after what you have been through
Thanks for the comments.
The old bearing have all been tossed out, We expect it was end float and part of the bearing rubbing on the back of the oil pump as it went past it.
To fix it up from the misshap I have had number 1 rod Resized 2½ thou, replaced the crank, had it machines to the correct clearences for what we want to rev it too and installed a new set of ACL Race series rb26 bearings for both mains and big ends.
Edited by murrayis
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
