So I've almost got everything together to come up the mount for the Crank Trigger sensor. I decided seeing I dont run AC that I would use this mounting point as its close by and offers good stable mounting.
So This is the design I will likely go with for the main arm, I haven't come up with the holder for the sensor yet as i'll likely just wing it.
Likely End product:
Over the top lite weight model:
Well I've been a little busy of late and finally had a few hours well more like 5 to start machining up tje crank sensor mount. Currently about 75% complete
Be kind I haven't used a mill in around 10 years!
Those hollowed out areas may have been better with a X left inside to reduce vibration flex/movement.
Also the sensor does not look square to the cutout wheel, it may be level but your approaching the wheel from below the crank center line, probably the sensor would be better turned a few degrees right.
Otherwise looks pretty good for someone having a go at home. :)
  • 6 years later...
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
