Okay guys.
So I know exactly what a surge tank is, I also know how to set one up.
My question however is WHY install a surge tank?
I mean I always planned to install one as I thought it was just one of those things you are supposed to do, especially if you have a high HP application.
However I have been doing some more research and talking to a number of people with high hp cars and they dont use a surge tank. Hell they look at me crazy for even talking about one.
Essentially the setup is very similar, just without the tank. They use a lift pump to get fuel out of the tank, then have the line running to a larger pump (or 2 pumps) then route it the way you normally would. They completely eliminate the surge tank.
So my question is, if it is not used because that is the only way to supply enough fuel to the system in high hp applications, what is the primary purpose to install a surge tank?
Thanks guys.
-Sayajin
  • Replies 40
so the fuel system doesn't get air in it due to the sloshing fuel in the tank, given the high rates of tank scavenge in big hp applications (and the sorts of driving such cars are used for)
Means there is a constant air free supply of fuel to the pressure pump. When dragging or circuit racing as your tank gets low and the fuel is being thrown around the pump can suck in air.....well thats my understanding of it....
Okay guys.
Thanks guys.
-Sayajin
Thank you very much for your question, which is more than wonderful ;) I wish more useful answers!!
oil surge....fuel surge. Both shit things especially in racing. Im surprised you know what one is and how to fit one up but yet not know the purpose behind it.
lol, I'm surprised too. especially since it's name pretty much sums up what it does. anyone (i assume) can see that you want your fuel pump sucking in 100% fuel in a straight line, under braking, around a corner etc ALL THE TIME. with a big arse fuel tank fuel will be moving away from the pick-up under all those conditions hence the need for a surge tank.
You don't need a surge tank if you are going to race (circuit or drag) with no less than 1/2 tank of fuel ALL the time.
The idea of a surge tank (say 3 litres) is so you don't have to carry around an extra 35 litres of fuel all the time.
At an SG of 0.75, that's a weight saving of 26 kgs.
:nyaanyaa: cheers :domokun:
bkc, you're cool dude, but can you please reduce the size of your font to the same as everyone elses and with no bold... My pupils get 5mm wider everytime i read your posts :nyaanyaa:.
thanks.
thanks.
When reading his posts I sit further away from the screen.
:domokun: cheers :P
Yeh or your stupid enough to put a 40 litre fuel cell in the boot which surges no soon as your fuel level drops below 30 litres....*points at self*
This is an interesting topic to me.
Going back you would never even consider trying to run up a gtr with 550rwhp on a single in-tank fuel pump.
Now it gets done all the time.
People used to spend $1000's on over complicated fuel systems that made your boot smell like a BP refinery.
I am wondering now what in-tank options can take you to 700rwhp.
A single intank bosch 044 seems good to about 550 - 600rwhp.
Does anyone know if you can fit Two bosch 044's through that nissan fuel tank hole ?
Is their a pump that can be mounted in-tank that flows more then an 044 ?
Edited by Butters
In tank, 2 x 044 mounted one above the other, the top one simply has a longer pick up hose to the strainer. Been done before.
:P cheers :banana:
You could put as many fuel pumps in your tank as you want but all it is reliable for is on the dyno or sitting still....
Start drag, circuit etc etc and see how well it works....and you cant say 'ill keep the tank full' cos it aint gonna happen with 700rwhp and a couple of laps.
Yeah fuel hose 'breathes' but if you run braided stuff it minimises the smell - to a point.
It's all braided. I realise that fuel hoses 'breathe', but the in cabin smell is unbearable even after 15 or 30 mins of parking car with windows closed, engine off. Open the door and you could almost pass out from the vapours. Luckily I don't smoke :P
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
