  • Replies 97
Posted Images
Been good reading guys, thanks.
If i hit 250 with a nice fat curve thru the middle, I'll be pretty damn happy :)
Just so you know, it'll be :
Z32
s15 injectors, 450cc
Tomei Fuel Pump
Power FC
FMIC
Zorst/Pod
I'll post it up soon enough....
  • 3 weeks later...
So the GTRS is the GT2535?... Is this the most popular street turbo for the rb25det, How much is it?
I have a:
Apexi power FC
E-boost
Apexi turbo timer
3" exhaust from turbo back
Front mount intercooler with custom piping
Custom cold air intake
Custom intake plenum
80mm throttle body
Im getting injectors the same time as the turbo as they are maxed out now.
Will i need the Z32 afm or will it be ok?
Would it be wise to get an aftermarket exhaust manifold? if so top mount or low mount?
Will the set up i have reach around the 250kw atw.
Thanks mate much appreciated. Slowly getting there.
Does the GTRS have a T3 flange? I was doing some searching on horsepowerinabox and from what i can figure they reckon the GTRS is for the sr20det's and the GT3076 would be better for the rb25det's?
The GT3037/3076 is an exceptional turbo for its HP range. It features a .6 surge slotted comp cover and a complimenting turbine/comp wheel ratio, making it a great bolt on upgrade for the 2-3 litre range engine.
This unit has a lot of flexibility in offered houisings. It can be supplied with a T25 .86 internal housing, a T3 .63 or .82 external gate housing and a recent edition is the option of internal gate T3 in .63 or .82 (these units are more expensive and subject to availability at the time). Usual ultra reliability and superb response from the Garrett ball bearing design.
Great upgrade for RB20/25s and other 2.5-3 litre's looking for some serious power.
I have a:
Apexi power FC
E-boost
Apexi turbo timer
80mm throttle body
The GTRS is NOT the GT2535. But due to the very similar power delivery, HKS dropped the GT2535 once the GTRS was released.
Are you claiming to have 250rwkw with those mods, on the std turbo? If so go to another tunner, as he is pullin' your chain :P
On the other hand; Very neat and clean engine bay, looks awesome :)
The GTRS is rated at approx. 380hp
The GT3076 is rated at 500hp
Two totally different turbos with different power curves. The GT3076 is also a great turbo, but will be laggier than a GTRS, on an rb25. In fact i have just purchased the GT3076 to replace my GTRS, as i am doing an RB30 coversion and the GTRS would have been too small and would have resticted the engine.
Oh, and why are you gettin ganother one?
Wouldn't you just rebuild the one you have? or is that what you mean?
I lost my dyno (it was 339hp but whos counting), but supporting mods were
FMIC
Fuel Pump
S-AFC-II
Split dump, 3.5" front pipe, 3.5" de-cat, 3.5" exhaust
16psi on EBC
I sold that one, i got pissed off with spending $$ on car, but now i got the bug again and bought a trusted/renowned great turbo :D
That said, I'll have this new one installed soon so I can post a dyno then :)
Are you claiming to have 250rwkw with those mods, on the std turbo? If so go to another tunner, as he is pullin' your chain :)
On the other hand; Very neat and clean engine bay, looks awesome :laugh:
he is asking once he gets the turbo and injectors done could he expect 250rkw out of the new set up.
Edited by fEkuaR
Nahh i got around 200rwkw now but i ment when i get the mods will i have around 250 like fEkuaR said.
Al
"In fact i have just purchased the GT3076 to replace my GTRS, as i am doing an RB30 coversion and the GTRS would have been too small and would have resticted the engine."
So what are u doing with your GTRS? selling :laugh:
The GTRS is a fair bit more powerful than the GT2535 hey.
Do they both spool up in roughly the same time?
Also can u get the GTRS externally gated as apose to internally? http://www.slidingperformance.com/catalog/...products_id=312
Pro's and con's?..........
There is a fair bit of info about the GTRS if you look around.
the best description I've heard is 'It has the response of a HKS2530 with the top end power of a HKS2540'
HKS2530 - supposed ot have ripper spool up as it;s quite small so you can't argue with that, but the top end, boost would drop off off as it choked and can't cope or whatever.
HKS2540 - Ripper top end but an absolute dog for lag etc.....only suitable for drags...
So combine the 2 and you have the GTRS
So, can we now keep this thread to be HKS2535 oriented?
Thanks peeps....
Al
So what are u doing with your GTRS? selling :sleep:
Sorry, my bad.
Am selling, but already have 2 potential buyers.
Since the turbo is less than 5,000 km old, i do not intend to give it away :P
  • 4 months later...
HKS 2535 is now tuned up to my satisfaction and it's a wee rippa.
Made 245.9rwkws on The Hitman's dyno which i don't think is a happy-reading dyno.
See the results in the dyno thread.
Spools up nicely and sounds great.
Vote 1 for HKS2535
And another vote for the s15 injectors which have done the job easily with more room to move(currently hitting about 80%)
I'm now guessing these babies are good for 270-280 rwkws.
That's it, anymore mods will be more along the lines of sell and by a Mitsubishi Mirage...tehe (seriously)
But I'm going to enjoy this one for awhile yet
Cheers guys :P
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
