The broker i imported my 32 through (Imports 101) is now the Australian agent for Drag and Drift.com and have some very nice cars for sale.
Here's one i thought my fellow Skyline enthusiasts would like to have a drool over -
http://www.imports101.com.au/view.php?car=1656
Very very nice specs list !!! :pwned:
https://www.sau.com.au/forums/topic/167558-trial-r34-gtr-time-attack/
Check out the last line
"Included in the price, TRIAL will fly to you and tune the setup to your local circuit as well as dyno the car to suit your requirements." haha not bad!
And what about this, never heard of liquid cooled brakes?!?!?
"BRAKES ARE: FRONT AP 6POT LIQUID COOLER CALIPER WITH FLUID COOLER
REAR BREMBO 4 POT "
vey nice indeed how ever i thought the ztune kits (any part) were not going to recirculated or be allowed to copy. is this true
Sort of...
Nismo will happily sell you a front bar and a set of front guards that are identical to the Z-tune variety except that they are FPR. The Z-Tune items are carbon fibre.
They are also quite pricey.
I believe you can have a set of front guards for $1600 - $1700 + shipping RRP.
Front bar is around the same at $1600 + shipping
Those prices might be wrong as im just going from memory.
REAR BREMBO 4 POT "
I was shocked when I saw that too! WRC cars use water cooled calipers, but I haven't seen them on a 'regular' car.
Top car though, looks really well built. I'll take 3 thanks :blink:
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
